[Geoserver-devel] [jira] (GEOS-6372) Add coverageBands customization capability on layer configuration
Daniele Romagnoli created an issue
GeoServer / ImprovementGEOS-6372
Issue Type:
ImprovementImprovement
Assignee:
Daniele Romagnoli
Components:
Wicket UI
Created:
27/Feb/14 3:23 AM
Priority:
MinorMinor
Reporter:
Daniele Romagnoli
Allowing customization of coverage band details on layer configuration would be a nice improvement.
Right now, you can only specify the unit of the band.
It would be good to also override the band name (as an instance, “elevation” instead of “GRAY_INDEX” for a DEM), the null values (force them to some value, as an instance, -999), as well as the range of valid values.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
