[Geoserver-devel] [jira] (GEOS-6379) Unable to add new default gridsets
Mike Pumphrey created an issue
GeoServer / BugGEOS-6379
Issue Type:
BugBug
Affects Versions:
2.4.4
Assignee:
Andrea Aime
Components:
GWC, UI, Wicket UI
Created:
04/Mar/14 11:38 AM
Environment:
Ubuntu 12
Fix Versions:
2.5-beta
Priority:
MinorMinor
Reporter:
Mike Pumphrey
On the Caching Defaults page, at the bottom where there is a link to “Add a new default grdiset”, the following stack trace occasionally occurs. It appears to be possible to delete existing gridsets,and create new ones,and add them, but no dice when trying to add default gridsets.
This is easily reproduced (at the time of writing) on the hosted instance at http://suite.opengeo.org/geoserver .
org.apache.wicket.WicketRuntimeException: Error attaching this container
for rendering: [MarkupContainer [Component id = listContainer]] at
org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1765)
at org.apache.wicket.Component.onBeforeRender(Component.java:3946) at
org.apache.wicket.Component.internalBeforeRender(Component.java:1071) at
org.apache.wicket.Component.beforeRender(Component.java:1105) at
org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753)
org.apache.wicket.Component.prepareForRender(Component.java:2292) at
org.apache.wicket.Component.prepareForRender(Component.java:2329) at
org.apache.wicket.ajax.AjaxRequestTarget.respondComponent(AjaxRequestTarget.java:830)
at
org.apache.wicket.ajax.AjaxRequestTarget.respondComponents(AjaxRequestTarget.java:682)
at
org.apache.wicket.ajax.AjaxRequestTarget.respond(AjaxRequestTarget.java:592)
at
org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
at
org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329) at
org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436) at
org.apache.wicket.RequestCycle.request(RequestCycle.java:545) at
org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484) at
org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637) at
javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at
org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:88)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at
org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:87)
at
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at
at
at
org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at
at
at
org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:115)
at
at
at
org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at
at
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42) at
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at
at
at
org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at
at
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602)
at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:701) Caused by:
java.lang.ArrayIndexOutOfBoundsException: 2 at
org.geoserver.web.wicket.GeoServerTablePanel$SelectionModel.getObject(GeoServerTablePanel.java:672)
at
org.apache.wicket.Component.getDefaultModelObject(Component.java:1720)
at org.apache.wicket.Component$3.compare(Component.java:548) at
org.apache.wicket.Component.setDefaultModelObject(Component.java:3122)
at
org.apache.wicket.markup.html.form.FormComponent.setModelObject(FormComponent.java:1680)
at
org.geoserver.gwc.web.gridset.GridSetListTablePanel.selectOneCheckbox(GridSetListTablePanel.java:99)
at
org.geoserver.web.wicket.GeoServerTablePanel$2.populateItem(GeoServerTablePanel.java:151)
at
org.apache.wicket.markup.repeater.RefreshingView$1.newItem(RefreshingView.java:114)
at
org.apache.wicket.markup.repeater.ReuseIfModelsEqualStrategy$1.next(ReuseIfModelsEqualStrategy.java:84)
at
org.apache.wicket.markup.repeater.ReuseIfModelsEqualStrategy$1.next(ReuseIfModelsEqualStrategy.java:96)
at
org.apache.wicket.markup.repeater.RefreshingView.addItems(RefreshingView.java:189)
at
org.apache.wicket.markup.repeater.RefreshingView.onPopulate(RefreshingView.java:98)
at
org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:131)
at
org.apache.wicket.markup.repeater.AbstractPageableView.onBeforeRender(AbstractPageableView.java:121)
at org.apache.wicket.Component.internalBeforeRender(Component.java:1071)
at org.apache.wicket.Component.beforeRender(Component.java:1105) at
... 108 more
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
