[Geoserver-devel] [jira] (GEOS-6397) Cannot publish geography column in 2.5 due to ST_Simplify
Michael Scholz created an issue
GeoServer / BugGEOS-6397
Issue Type:
BugBug
Affects Versions:
2.5-RC1
Assignee:
Andrea Aime
Created:
13/Mar/14 5:30 AM
Labels:
ST_Simplify geography GeoServer
Priority:
CriticalCritical
Reporter:
Michael Scholz
Heho!
In GeoServer 2.5 (in my case RC1) there was a new feature introduced: “Use of ST_Simplify to improve PostGIS rendering performance”. So far so good but now I cannot publish PostGIS tables with geography columns any more. I get the following error.
DE:
> org.postgresql.util.PSQLException: FEHLER: Funktion st_simplify(geography, numeric) existiert nicht
EN:
> org.postgresql.util.PSQLException: ERROR: function st_simplify(geography, numeric) does not exist
When publishing my layer I use a projected UTM SRS as “Declared SRS” which should result in a geometry rather than a geography. So the introduced simplification takes place before the projection.
Genießt die Sonne!!
Michi
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
