[Geoserver-devel] [jira] (GEOS-6410) LookAt value in SimpleNetworkLinkBuilder not set correctly
markus innerebner created an issue
GeoServer / BugGEOS-6410
Issue Type:
BugBug
Affects Versions:
2.4.5
Assignee:
Andrea Aime
Components:
Google Earth KML Output
Created:
20/Mar/14 10:38 AM
Environment:
Linux, Java JDK 1.6
Priority:
MinorMinor
Reporter:
markus innerebner
When the KML file is created, the LookAt value is never set correctly. Is is used the wrong bounding box.
There should not be used the bounding box of the layer but instead the one from the request.
You can find the solution in my github https://github.com/markusin/geoserver/ fork in version 2.4.x
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
