[Geoserver-devel] [jira] (GEOS-6414) WMS-T time range query incorrect
Chris Van Orman created an issue
GeoServer / BugGEOS-6414
Issue Type:
BugBug
Affects Versions:
2.5
Assignee:
Andrea Aime
rangeQuery.patch
Components:
WMS
Created:
24/Mar/14 3:33 PM
Environment:
All
Priority:
MinorMinor
Reporter:
Chris Van Orman
Making a WMS call against a layer with an effective and expiry date using a TIME parameter with a range results in an incorrect filter. The filter built is ‘effective_date BETWEEN [range] OR expiry_date BETWEEN [range]’. This does not handle the case when the given range parameter is entirely inside the effective_date and expiry_date.
For example, given a feature with an effective_date of ‘2011-01’ and a expiry_date of ‘2011-04’. A time range query of ‘2011-02/2011-03’ returns no results when I would think it should.
I’ve included a patch that changes this logic to ‘effective_date <= [range.end] AND expiry_date >= [range.start]’.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
