[Geoserver-devel] [jira] (GEOS-6418) WMS "Library Mode" error
Diego Guidi created an issue
GeoServer / BugGEOS-6418
WMS “Library Mode” error
Issue Type:
BugBug
Affects Versions:
2.5
Assignee:
Andrea Aime
wms_request
Components:
WMS
Created:
28/Mar/14 6:18 AM
Environment:
geoserver 2.5 “binary os” installation with windows 7 and JRE 1.6
Priority:
MinorMinor
Reporter:
Diego Guidi
As described in this thread: http://osgeo-org.1560.x6.nabble.com/WMS-quot-Library-Mode-quot-request-td5131616.html, I’ve tried to generate a wms request for two layers using sld_body parameter as “LibraryMode”, as described here: http://docs.geoserver.org/latest/en/user/styling/sld-working.html#sld-library-mode.
I’ve built an example url using some layers from tiger-data: see attached document.
Here a url-like string to explain what I’ve tried to do:
http://mygeoserver/wms?layers=poly_landmarks,poi&styles=,poi&bbox=…&sld_body=
I request two layers:
  • the first has no “styles” parameter, but the stile is specified in the sld_body
  • the second has “styles” parameter, and points to a sld inside geoserver.
I expected to see the two layers rendered with the specified styles, but a ServiceException is thrown:
" java.lang.ArrayIndexOutOfBoundsException: 1
1"
Note that the same url WITHOUT sld_body works perfectly, and uses the default style for the first layer (as expected).
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
