David Pilcher created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.5 |
Assignee: |
Created: |
31/Mar/14 9:24 AM |
Environment: |
Windows 7/IE11 |
Priority: |
Critical |
Reporter: |
With Microsoft pushing IE update out it is important that GeoServer works in the latest IE. IE11 has major issues in configuring the website. An example is:
However
The fact that functionality does not uniformly work means you have to keep changing Compatibility Mode for the page you are trying to use to make it work. Not ideal! |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
