Jonathan Moules created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.5 |
Assignee: |
Attachments: |
logs.zip |
Created: |
31/Mar/14 9:57 AM |
Priority: |
Critical |
Reporter: |
(also affects 2.4.3) As you can see: It returns an invalid GetCapabilities - there’s an exception error at the end. Despite the implication that the issue is with “Historical_Maps:2500ep1Warwickshire_processed” (the last working layer) - it’s almost certainly not. That layer has been untouched for many months. I’ve already deleted the previous candidate which was the last item on this list and the issue didn’t change - it just moved. Attached are debug level logs. Also included are the getcapabilities, plus the “previous error.xml” - which is the what it said before I deleted the last apparently-guilty layer (it was blaming “Public_HS2:AGC_FARM_HOLDINGS” - now deleted). No clue what induced this. |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
