[Geoserver-devel] [jira] (GEOS-6438) JDBCConfig can't handle large properties
Kevin Smith created an issue
GeoServer / BugGEOS-6438
JDBCConfig can’t handle large properties
Issue Type:
BugBug
Affects Versions:
2.5, 2.4.5
Assignee:
Kevin Smith
Components:
JDBCConfig
Created:
04/Apr/14 1:35 PM
Environment:
Postgres
Priority:
MajorMajor
Reporter:
Kevin Smith
Properties larger than 255 characters will cause an error in JDBCConfig. This is a problem for free form text fields like Abstract. The update/insert will fail if this happens.
Changing the schema to allow larger values fixes the problem.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
