Jody Garnett created an issue |
Issue Type: |
Bug |
Assignee: |
Created: |
23/Apr/14 7:02 AM |
Priority: |
Major |
Reporter: |
GEOS-6461 I have noticed build issues when using maven -T2.
Testing further shows the build is suffering some consistency troubles with -T2
- http://ares.opengeo.org/jenkins/job/geoserver-master/457/ (fail)
- http://ares.opengeo.org/jenkins/job/geoserver-master/458 (works no change)
This shows a failure in GWCDataSecuritytest failing to unzip applicationSecurityContext.xml from gs-main jar:
org.springframework.beans.factory.BeanDefinitionStoreException: Unexpected exception parsing XML document from URL [jar:file:/var/lib/jenkins/workspace/geoserver-master/src/main/target/gs-main-2.6-SNAPSHOT.jar!/applicationSecurityContext.xml]; nested exception is java.lang.NullPointerException
Locally I have wms_1-1_1 GetFeatureInfoTest failure based on thrown exception These were not reproducible between runs, or from eclipse, seems to be luck of the draw.
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
