Carlo Cancellieri created an issue |
CSSDemoPage may create the sld file before a CatalogAddEvent is fired |
Issue Type: |
Bug |
Assignee: |
Created: |
30/Apr/14 11:19 AM |
Priority: |
Major |
Reporter: |
Hi, This implementation works fine with the event generated from: org.geoserver.wms.web.data.StyleNewPage.onStyleFormSubmit() which writes the SLD to the FileSystem then fire the event. Using the CssDemoPage when I try to create the css the event is fired but the file does not exists on the FileSystem. Looking at the CssDemoPage.createCssTemplate() the patch seems quite simple |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
