[Geoserver-devel] [jira] (GEOS-6467) UI bug in disabling tile caching for layers
Benjamin Trigona-Harany created an issue
GeoServer / BugGEOS-6467
Issue Type:
BugBug
Affects Versions:
2.5
Assignee:
Andrea Aime
Created:
30/Apr/14 11:46 AM
Priority:
MinorMinor
Reporter:
After a layer’s cache is disabled, when you return in the UI it is enabled again.
  1. Go to Tile Layers
  2. Click on any of the tile layers in the list to open settings
  3. Disable Enable tile caching for this layer
  4. Click Save
  5. The Tile Layers list will show the layer as disabled
  6. Click on the same layer again to enter the settings
  7. The Enable tile caching for this layer box is checked again
  8. At this point Cancel will leave it disabled and Save will enable it
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
