[Geoserver-devel] [jira] (GEOS-6474) problem using different palettes
Jakob Ventin created an issue
GeoServer / BugGEOS-6474
Issue Type:
BugBug
Affects Versions:
2.5
Assignee:
Andrea Aime
Created:
05/May/14 3:00 AM
Environment:
rhel, tomcat 6
Priority:
MajorMajor
Reporter:
Jakob Ventin
It seems, that (after Tomcat restart) the first palette file to be used in a wms getmap request, will be used in all other wms getmap requests, that have &palette= defined, as well. To make it clear, even if we define another palette in the wms getmap request, the one that has been used first (after tomcat restart) will be called.
‘Clear cache’ or ‘Reload configuration’ does not help, the only way to use a new palette file is to restart Tomcat and make a wms getmap request.
(If no palette is defined, the output is a normal png8 without any palette definitions)
http://osgeo-org.1560.x6.nabble.com/problem-using-different-palettes-td5137653.html
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
