[Geoserver-devel] [jira] (GEOS-6476) Animate reflector request fails due to NPE in WMS-EO Plugin
Torsten Heinen created an issue
GeoServer / BugGEOS-6476
Issue Type:
BugBug
Affects Versions:
2.5
Assignee:
Andrea Aime
Created:
06/May/14 3:30 AM
Environment:
Linux
Priority:
MajorMajor
Reporter:
Torsten Heinen
I’ve tried to create an animation over time (“&aparam=time&avalues=2013-07-01T00:00:00.000Z,2013-07-04T00:00:00.000Z”) on one of our layers but it failed due to an NPE in the WMS EO plugin.
This can also be reproduced with the standard data in GeoServer-2.5:
http://localhost:8080/geoserver/wms/animate?layers=nurc:mosaic&aparam=BBOX&avalues=6,36,20,46;7,37,21,47&format=image/gif;subtype=animated&format_options=layout:message
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc http://localhost:8080/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd">
  <ServiceException>
      java.lang.RuntimeException: java.io.IOException: java.util.concurrent.ExecutionException: java.lang.NullPointerException
null
Details:
org.geoserver.platform.ServiceException: java.lang.RuntimeException: java.io.IOException: java.util.concurrent.ExecutionException: java.lang.NullPointerException
	at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1580)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:282)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
	at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:92)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
	at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
	at org.apache.tomcat.util.net.AprEndpoint$SocketWithOptionsProcessor.run(AprEndpoint.java:2378)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:744)
Caused by: java.lang.RuntimeException: java.io.IOException: java.util.concurrent.ExecutionException: java.lang.NullPointerException
	at org.geoserver.wms.DefaultWebMapService.animate(DefaultWebMapService.java:374)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
	at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
	at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:54)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
	at com.sun.proxy.$Proxy78.animate(Unknown Source)
	at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
	... 88 more
Caused by: java.io.IOException: java.util.concurrent.ExecutionException: java.lang.NullPointerException
	at org.geoserver.wms.animate.FrameCatalogVisitor.produce(FrameCatalogVisitor.java:99)
	at org.geoserver.wms.animate.Animator.produce(Animator.java:128)
	at org.geoserver.wms.DefaultWebMapService.animate(DefaultWebMapService.java:372)
	... 107 more
Caused by: java.util.concurrent.ExecutionException: java.lang.NullPointerException
	at java.util.concurrent.FutureTask.report(FutureTask.java:122)
	at java.util.concurrent.FutureTask.get(FutureTask.java:188)
	at org.geoserver.wms.animate.FrameCatalogVisitor.produce(FrameCatalogVisitor.java:93)
	... 109 more
Caused by: java.lang.NullPointerException
	at org.geoserver.wms.eo.EOGetMapChecker.beforeRender(EOGetMapChecker.java:54)
	at org.geoserver.wms.GetMap.fireBeforeRender(GetMap.java:155)
	at org.geoserver.wms.GetMap.executeInternal(GetMap.java:508)
	at org.geoserver.wms.GetMap.run(GetMap.java:253)
	at org.geoserver.wms.GetMap.run(GetMap.java:124)
	at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:328)
	at org.geoserver.wms.animate.FrameLoader.call(FrameCatalogVisitor.java:216)
	at org.geoserver.wms.animate.FrameLoader.call(FrameCatalogVisitor.java:155)
	at java.util.concurrent.FutureTask.run(FutureTask.java:262)
	... 3 more
</ServiceException>
</ServiceExceptionReport>
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
