[Geoserver-devel] [jira] (GEOS-6502) stroke-Dasharray style partially breaks WMS getfeatureinfo
Casper Span created an issue
GeoServer / BugGEOS-6502
Issue Type:
BugBug
Affects Versions:
2.5.1, 2.5
Assignee:
Andrea Aime
poly_landmarks.sld
Components:
WMS
Created:
28/May/14 6:09 AM
Environment:
Windows 8.1, Geoserver within Jetty
Labels:
wms getfeatureinfo sld
Priority:
MinorMinor
Reporter:
Casper Span
I’ve been running 2.5.0 for a bit and noticed some strange behavior. When further investigating I also found this behavior to be present on 2.5.1.
It unfolds as follows.
  1. create a new style, or edit an existing style made for polygons
  2. add a stroke dasharray to the stroke in the polygonsymbolizer:
    <CssParameter name=“stroke-dasharray”>4 3</CssParameter>
  3. make sure you know what layer uses this style and open it in geoserver’s layer preview
  4. click on one of the polygons on the map that has a dashed border. First click the border, then somewhere well inside the polygon
For me, I will only get data when clicked on the border, no data when clicking within the polygon bounds.
I’ve run this test on SQL Server, and noticed the query is being run in both cases and also return the expected result (1 record). I have also tested this on the tiger_ny set by adding a dasharray to the landmarks style. (added as attachement)
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
