Tobias Warneke created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.5.1 |
Assignee: |
Attachments: |
exception.txt |
Created: |
18/Jun/14 5:19 AM |
Priority: |
Major |
Reporter: |
I have an existing image mosaic from an earlier version of geoserver. This one I created manually (the properties file, shp) and it worked. Now using GeoServer 2.5.1 if I want to config this image mosaic I get the attached exception. My first investigation seems to show, that the missing sample_image file within my image mosaic directory is the problem. By the way, if I let the new image mosaic plugin collect all data and create the files (shp, properties, …) the mosaic works fine. But if I delete the created sample_data file, I get the same exception as above. In the provided sample mosaic of geoserver there is no sample_data as well, so it seems to be a geoserver configuration page problem and not a problem of geotools. |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
