Ben Caradoc-Davies created an issue |
GSIP 106 ResourceStore API changes cause build failure in gs-main in path with spaces |
Issue Type: |
Bug |
Affects Versions: |
2.6-beta |
Assignee: |
Attachments: |
org.geoserver.catalog.ResourcePoolTest.txt, org.geoserver.config.GeoServerPersisterTest.txt |
Components: |
Global |
Created: |
24/Jun/14 1:15 AM |
Environment: |
Apache Maven 3.2.1 (ea8b2b07643dbb1b84b6d16e1f08391b666bc1e9; 2014-02-15T01:37:52+08:00) |
Priority: |
Critical |
Reporter: |
Failed tests: testModifyStyleWithResourcesAbsoluteChangeWorkspace(org.geoserver.config.GeoServerPersisterTest): (…) Tests in error: Tests run: 576, Failures: 18, Errors: 1, Skipped: 1 |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
