[Geoserver-devel] [jira] (GEOS-6558) GEOSERVER_AUDIT_PATH ignored
Tom Kunicki created an issue
GeoServer / BugGEOS-6558
Issue Type:
BugBug
Affects Versions:
2.5.1
Assignee:
Andrea Aime
Components:
Monitoring
Created:
30/Jun/14 1:52 AM
Environment:
Any
Priority:
MinorMinor
Reporter:
Tom Kunicki
From a code review:
In developing a GeoServer log archival extension I looked at the github master branch AuditLogger.java source to determine how to extract the audit log directory . On line 86 the system property GEOSERVER_AUDIT_PATH is read and then, if present, validated. Then on line 106 this value is overwritten with a another getProperty(...) call. Is it possible that line 106 should be a setProperty(...)?
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
