Hello,
I’m having an issue with the GWC which is not seeding any layers. I’ve got a trace stack and wondered if someone could point out which bit is the real problem. There is some security but I’ve taken it off the layer I was trying to seed and the only bit that seems to be common to all is the No workspace specified and Problem communicating lines.
Any help would be appriciated, stack is below:
2014-07-01 17:17:34,408 DEBUG [geoserver.logging] - FINISHED CONFIGURING GEOSERVER LOGGING -------------------------
2014-07-01 17:17:34,408 DEBUG [org.geoserver] - Thread 49 releasing the lock in mode WRITE
2014-07-01 17:17:34,423 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2014-07-01 17:17:34,439 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2014-07-01 17:17:34,439 DEBUG [org.geoserver] - Thread 48 locking in mode READ
2014-07-01 17:17:34,439 DEBUG [org.geoserver] - Thread 48 got the lock in mode READ
2014-07-01 17:17:34,533 DEBUG [geoserver.security] - Bad credentials
org.springframework.security.authentication.BadCredentialsException: Bad credentials
at org.springframework.security.authentication.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:137)
at org.geoserver.security.auth.UsernamePasswordAuthenticationProvider.authenticate(UsernamePasswordAuthenticationProvider.java:81)
at org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:57)
at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:156)
at org.geoserver.security.GeoServerSecurityManager.checkForDefaultAdminPassword(GeoServerSecurityManager.java:1326)
at org.geoserver.security.web.SecurityHomePageContentProvider$SecurityWarningsPanel.<init>(SecurityHomePageContentProvider.java:106)
at org.geoserver.security.web.SecurityHomePageContentProvider.getPageBodyComponent(SecurityHomePageContentProvider.java:44)
at org.geoserver.web.GeoServerHomePage$1.populateItem(GeoServerHomePage.java:132)
at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:562)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:131)
at org.apache.wicket.Component.internalBeforeRender(Component.java:1071)
at org.apache.wicket.Component.beforeRender(Component.java:1105)
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753)
at org.apache.wicket.Component.onBeforeRender(Component.java:3946)
at org.apache.wicket.Page.onBeforeRender(Page.java:1531)
at org.apache.wicket.Component.prepareForRender(Component.java:2292)
at org.apache.wicket.Page.prepareForRender(Page.java:1521)
at org.apache.wicket.Component.prepareForRender(Component.java:2329)
at org.apache.wicket.Page.renderPage(Page.java:892)
at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.respond(BookmarkablePageRequestTarget.java:261)
at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:668)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1550)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:343)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:217)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:92)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:182)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:115)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:279)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:655)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:595)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:161)
at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:331)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:231)
at com.sun.enterprise.v3.services.impl.ContainerMapper$AdapterCallable.call(ContainerMapper.java:317)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:195)
at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:860)
at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:757)
at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:1056)
at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:229)
at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:137)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:104)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:90)
at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:79)
at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:54)
at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:59)
at com.sun.grizzly.ContextTask.run(ContextTask.java:71)
at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:532)
at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:513)
at java.lang.Thread.run(Thread.java:662)
2014-07-01 17:17:34,580 DEBUG [org.geoserver] - Thread 48 releasing the lock in mode READ
2014-07-01 17:17:34,580 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2014-07-01 17:17:34,580 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2014-07-01 17:17:42,674 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: ‘/gwc/rest/seed/mapping:10k’; to: ‘/gwc/rest/seed/mapping:10k’ and httpMethod= GET
2014-07-01 17:17:42,689 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2014-07-01 17:17:42,689 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/gwc/rest/seed/mapping:10k’; antPath is /; matchedPath=true; matchedMethods=true
2014-07-01 17:17:42,689 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
2014-07-01 17:17:42,689 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/gwc/rest/seed/mapping:10k]
2014-07-01 17:17:42,689 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=ISO-8859-1
2014-07-01 17:17:42,689 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2014-07-01 17:17:42,830 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/gwc/rest/web/geowebcache_logo.png]
2014-07-01 17:17:42,830 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2014-07-01 17:17:42,830 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2014-07-01 17:17:51,033 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: ‘/gwc/rest/seed/mapping:10k’; to: ‘/gwc/rest/seed/mapping:10k’ and httpMethod= POST
2014-07-01 17:17:51,033 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= / methodList= [GET]
2014-07-01 17:17:51,033 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/gwc/rest/seed/mapping:10k’; antPath is /; matchedPath=true; matchedMethods=false
2014-07-01 17:17:51,033 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= / methodList= [POST, DELETE, PUT]
2014-07-01 17:17:51,033 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/gwc/rest/seed/mapping:10k’; antPath is /**; matchedPath=true; matchedMethods=true
2014-07-01 17:17:51,033 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
2014-07-01 17:17:51,033 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/gwc/rest/seed/mapping:10k]
2014-07-01 17:17:51,033 INFO [seed.SeedTask] - GWC Seeder Thread-10 begins seeding layer : mapping:10k
2014-07-01 17:17:51,033 DEBUG [gwc.layer] - –> GWC Seeder Thread-10 submitting getMap request for meta grid location [0, 0, 0] on org.geoserver.gwc.layer.GeoServerMetaTile@anonymised.com
2014-07-01 17:17:51,033 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: No workspace specified
at org.geoserver.ows.LocalWorkspaceCallback.init(LocalWorkspaceCallback.java:77)
at org.geoserver.ows.Dispatcher.fireInitCallback(Dispatcher.java:389)
at org.geoserver.ows.Dispatcher.init(Dispatcher.java:384)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:243)
at org.geoserver.gwc.GWC.dispatchOwsRequest(GWC.java:1162)
at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:572)
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:517)
at org.geoserver.gwc.layer.GeoServerTileLayer.seedTile(GeoServerTileLayer.java:711)
at org.geowebcache.seed.SeedTask.doActionInternal(SeedTask.java:136)
at org.geowebcache.seed.GWCTask.doAction(GWCTask.java:76)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:36)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:25)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
2014-07-01 17:17:51,049 INFO [seed.GWCTask] - Thread group finished SEED task after 0.016 seconds
2014-07-01 17:17:51,049 ERROR [seed.MTSeeder] - Problem communicating with GeoServer
org.geowebcache.GeoWebCacheException: Problem communicating with GeoServer
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:522)
Caused by: java.lang.IllegalStateException: Expected: RenderedImageMap, got null
at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:575)
… 10 more
2014-07-01 17:17:51,549 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=ISO-8859-1
2014-07-01 17:17:51,549 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2014-07-01 17:17:51,658 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/gwc/rest/web/geowebcache_logo.png]
2014-07-01 17:17:51,674 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2014-07-01 17:17:51,674 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2014-07-01 17:17:56,440 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2014-07-01 17:17:56,440 DEBUG [org.geoserver] - Thread 49 locking in mode WRITE
2014-07-01 17:17:56,440 DEBUG [org.geoserver] - Thread 49 got the lock in mode WRITE
2014-07-01 17:17:56,486 DEBUG [org.geoserver] - Thread 49 releasing the lock in mode WRITE
2014-07-01 17:17:56,486 DEBUG [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
2014-07-01 17:17:56,486 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2014-07-01 17:18:00,080 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/]
2014-07-01 17:18:00,080 DEBUG [org.geoserver] - Thread 51 locking in mode WRITE
2014-07-01 17:18:00,080 DEBUG [org.geoserver] - Thread 51 got the lock in mode WRITE
2014-07-01 17:18:00,112 DEBUG [geoserver.logging] - CONFIGURING GEOSERVER LOGGING -------------------------
2014-07-01 17:18:00,127 DEBUG [geoserver.logging] - GeoServer logging profile ‘PRODUCTION_LOGGING.properties’ enabled.
Paul
