[Geoserver-devel] [jira] (GEOS-6563) SQL Server import doesn't preserve geometry SRID's
Justin Deoliveira created an issue
GeoServer / BugGEOS-6563
SQL Server import doesn’t preserve geometry SRID’s
Issue Type:
BugBug
Assignee:
Justin Deoliveira
Components:
Importer
Created:
03/Jul/14 4:08 PM
Fix Versions:
2.5.1
Priority:
MajorMajor
Reporter:
Justin Deoliveira
Reason being that unlike postgis we don;t have a geometry columns table to look up the srid from. Should be easily fixable by having the importer pass through the CRS via geometry user data (or pass through the srid on the geometry object itself). The JDBC datastores (including sql server) will pick that up.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
