[Geoserver-devel] [jira] (GEOS-6564) WCS GranuleStack for mosaic contains duplicate entries
Jeroen Dries created an issue
GeoServer / BugGEOS-6564
Issue Type:
BugBug
Affects Versions:
2.5.1
Assignee:
Andrea Aime
Components:
WCS
Created:
07/Jul/14 2:51 AM
Priority:
MajorMajor
Reporter:
Jeroen Dries
This happens when using the multidimensional WCS export feature in combination with an image mosaic.
When the request bounding box covers multiple granules, the WCSDimensionSubsetHelper#splitRequest code will create a new subrequest for each input granule. However, it should recognize that certain granules belong to the same 2D slice.
A simple way to detect duplicate subrequests should do the trick. I’m attaching a unit test which exposes the issue.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
