[Geoserver-devel] JIRA GEOS-6568 needs to be fixed yet
the GEOS-6568 (https://jira.codehaus.org/browse/GEOS-6568) seems to be not solved yet.
I have the same problem as described into the JIRA.
I tried to publish an SLD into the latest Geoserver stable release v. 2.6.2 and also into the master branch but it is not possible to post 1.1.0 sld styles using the rest API and the appropriate new content type i.e. using:
curl -v -u admin:geoserver -XPOST -H “Content-type: application/vnd.ogc.se+xml” -d @pse_bnd_oslo2_ocha.sld http://localhost:8989/geoserver/rest/styles
at the end of publish phase the GS sld file laks of its content.
Is there a pull request that I can try to apply to fix this issue?
Thanks
Nazzareno Sileno
CNR - IMAA
geoSDI
Sviluppo Software
C.da S. Loja
85050 Tito Scalo - POTENZA (PZ)
Italia
phone: +39 0971427305
fax: +39 0971 427271
mob: +39 3207297545
mail: nazzareno.sileno@anonymised.com
skype: andypowerxyz
web: http://www.geosdi.org
On Wed, Mar 11, 2015 at 4:32 PM, Nazzareno Sileno <
nazzareno.sileno@anonymised.com> wrote:
<https://jira.codehaus.org/browse/GEOS-6568&gt; seems to be not solved yet.
using:
curl -v -u admin:geoserver -XPOST -H "Content-type: application/vnd.ogc.se+xml"
Not that I know of... but if you can code you could make one? :slight_smile:
As to what expect in terms of bug fixing times, the user list posting
guidelines has an answer (see "if it turns out to be a bug"):
http://geoserver.org/comm/userlist-guidelines.html
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
