[Geoserver-devel] [jira] (GEOS-6568) Uploading SLD's with version 1.1.0 doesn't work through REST interface
Wouter Schaubroeck created an issue
GeoServer / BugGEOS-6568
Uploading SLD’s with version 1.1.0 doesn’t work through REST interface
Issue Type:
BugBug
Affects Versions:
2.5.1
Assignee:
Andrea Aime
sld110.sld
Components:
REST
Created:
10/Jul/14 6:03 AM
Priority:
MajorMajor
Reporter:
Wouter Schaubroeck
Is it possible that registering a SLD with version 1.1.0 is not possible through the REST interface.
It’s reproducable with curl:
First try this:
curl -v -u admin:geoserver -XPOST -H “Content-type: text/xml” -d “<style><name>test110_style</name><filename>sld110.sld</filename><sldVersion><version>1.1.0</version></sldVersion></style>” http://localhost:8080/geoserver/rest/styles
-> HTTP 200 Ok
Then uploading the sld:
curl -v -u admin:geoserver -XPUT -H “Content-type: application/vnd.ogc.sld+xml” -d @sld110.sld http://localhost:8080/geoserver/rest/styles/test110_style
-> Also an HTTP/1.1 200 OK
Then, when trying to retrieve the sld:
curl -v -u admin:geoserver -XGET http://localhost:8080/geoserver/rest/styles/test110_style.sld
The answer is:
< HTTP/1.1 500 Internal Server Error
The same procedure with a SLD version 1.0.0 works, and through the GUI the 1.1.0 SLD also works.
Wouter
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
