Jody Garnett created an issue |
Unable to unwrap OracleConnection from JBoss WrappedConnectionJDK6 |
Issue Type: |
Bug |
Affects Versions: |
2.4.7 |
Assignee: |
Components: |
Oracle |
Created: |
17/Jul/14 3:29 PM |
Priority: |
Major |
Reporter: |
Marking this as a GeoServer issue (even though the error occurs at the GeoTools level). GeoServer should be in position to donate a UnWrapper for use in OracleDialect:
And since this is a Tomcat deployment issue it is probably GeoServer’s job to do (or Spring’s job to do). Previous email discussion shows this as a recurring problem: Advice in that thread is to upgrade to the latest version of Spring in the hopes the Spring project has implemented an appropriate unwrapped for each application container. Notes:
I am tempted to do two things to address this issue:
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
