[Geoserver-devel] [jira] (GEOS-6587) Installer should set start.bat to run as Administrator
Jody Garnett created an issue
GeoServer / BugGEOS-6587
Issue Type:
BugBug
Affects Versions:
2.6-beta
Assignee:
Mike Pumphrey
Components:
Windows Installer
Created:
23/Jul/14 12:36 PM
Environment:
Windows 7
Fix Versions:
2.5.2
Priority:
MajorMajor
Reporter:
No Reporter
Running GeoServer using the start.bat does not work - fails due to file permission on the data directory. I have tried changing the file permission on the data directory without success - twitter has provided the following workaround.
To fix the Start (or Stop) shortcut:
  1. Right click on short cut to open Start properties
  2. From the Shortcut tab click on Advanced
  3. From Advanced Properties ensure “Run as Administrator” is checked
When you next run the start short cut, windows will ask for confirmation “Do you want the following program to make changes to your computer” before running the script that starts the GeoServer service in the background.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
