Ben Khoo created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.5 |
Assignee: |
Attachments: |
test_shp.zip |
Components: |
REST |
Created: |
13/Aug/14 3:22 AM |
Environment: |
– Operating System – – JVM Version – – Geoserver – Git Revision Build Date GeoTools Version |
Labels: |
rest url escape |
Priority: |
Major |
Reporter: |
Hi, I think I have found an issue with the Geoserver REST API when it comes to escaping shapefile names containing a whitespace. Here is an example, Using the shapefile attached, execute the following curl -v -u adminassword -XPUT -H “Content-type: text/plain” -d “file:///tmp/tasmania roads.shp” http://localhost:8080/geoserver/rest/workspaces/topp/datastores/test/external.shp I would expect to see a new layer called “tasmania roads” in a new datastore called “test” in the “topp” workspace. The workspace and datastore are fine however the layer is called “tasmania%20roads”. This is turn breaks the layer preview with Geoserver returning the error, I have had a look at the issues currently lodged in Jira and it appears that there are no open tickets for this issue however the two issues linked below seem to have the same theme of escaping REST URLs. http://jira.codehaus.org/browse/GEOS-4140 Cheers |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
