[Geoserver-devel] [jira] (GEOS-6616) Better management of attribute cache information
Jody Garnett created an issue
GeoServer / BugGEOS-6616
Issue Type:
BugBug
Affects Versions:
2.4.8, 2.5.3, 2.6-RC1
Assignee:
Jody Garnett
Components:
REST
Created:
14/Aug/14 6:14 PM
Priority:
CriticalCritical
Reporter:
Jody Garnett
Quick follow up to testing GEOS-6575 in an abusive clustered environment.
  • Good news: Removing several calls to clear the ResourcePool datastore cache was effective
  • Bad news: clearing of the DataStore cache was being used as an undocumented way of forcing GeoServer to recognise when database columns had been added or removed
DELETE
  • Quickly restore previous “burn the ground” functionality to FeatureType DELETE
  • Special case in a call to ContentState.flush() to allow JDBCDataStore implementations to detect the addition of additional columns without full on reset effecting other FeatureTypes
PUT / PUSH
Can look at introducing a call to ContentState.flush() before geotools schema is used to in the production/validation of FeatureTypeInfo
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
