The following are two queries that I captured from the layer preview. The first query works and the second query does not. The only difference between the two queries is that the info_format is changed from text/html to application/json.
Query 1 - (working)
http://localhost:8080/geoserver/nurc/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=application/vnd.ogc.se_xml&BBOX=-142.146773,15.222861,-50.710307,59.596439&SERVICE=WMS&INFO_FORMAT=text/html&QUERY_LAYERS=nurc:Img_Sample&FEATURE_COUNT=50&Layers=nurc:Img_Sample&WIDTH=680&HEIGHT=330&format=image/jpeg&styles=&srs=EPSG:4326&version=1.1.1&x=338&y=161
Query 2 - (not working)
http://localhost:8080/geoserver/nurc/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=application/vnd.ogc.se_xml&BBOX=-142.146773,15.222861,-50.710307,59.596439&SERVICE=WMS&INFO_FORMAT=application/json&QUERY_LAYERS=nurc:Img_Sample&FEATURE_COUNT=50&Layers=nurc:Img_Sample&WIDTH=680&HEIGHT=330&format=image/jpeg&styles=&srs=EPSG:4326&version=1.1.1&x=338&y=161
The geoserver log produces this exception.
2014-08-26 14:48:26,208 INFO [geoserver.wms] -
Request: getServiceInfo
2014-08-26 14:48:26,223 INFO [geoserver.wms] -
Request: getFeatureInfo
PropertyNames = null
QueryLayers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
FeatureCount = 50
GetMapRequest =
GetMap Request
version: 1.1.1
output format: image/jpeg
width height: 680,330
bbox: SRSEnvelope[-142.146773 : -50.710307, 15.222861 : 59.596439]
layers: nurc:Img_Sample
styles: raster
InfoFormat = application/json
XPixel = 338
YPixel = 161
Exceptions = application/vnd.ogc.se_xml
Get = false
BaseUrl = http://192.168.2.207:8080/geoserver/
RawKvp =
{INFO_FORMAT=application/json, BBOX=-142.146773,15.222861,-50.710307,59.596439, QUERY_LAYERS=nurc:Img_Sample, SERVICE=WMS, HEIGHT=330, REQUEST=GetFeatureInfo, STYLES=, WIDTH=680, EXCEPTIONS=application/vnd.ogc.se_xml, FEATURE_COUNT=50, VERSION=1.1.1, FORMAT=image/jpeg, LAYERS=nurc:Img_Sample, Y=161, X=338, SRS=EPSG:4326}
RequestCharset = null
Version = 1.1.1
Request = GetFeatureInfo
2014-08-26 14:48:26,224 INFO [wfs.json] - about to encode JSON
2014-08-26 14:48:26,224 ERROR [geoserver.ows] -
java.lang.NullPointerException
at org.geoserver.wfs.json.GeoJSONGetFeatureResponse.write(GeoJSONGetFeatureResponse.java:189)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:193)
at org.geoserver.wms.featureinfo.GeoJSONFeatureInfoResponse.write(GeoJSONFeatureInfoResponse.java:48)
at org.geoserver.wms.featureinfo.GetFeatureInfoResponse.write(GetFeatureInfoResponse.java:108)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:936)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:277)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:313)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
