[Geoserver-devel] [jira] (GEOS-6634) CQL for filtering the view by 'id' property
fran peru?i? created an issue
GeoServer / BugGEOS-6634
CQL for filtering the view by ‘id’ property
Issue Type:
BugBug
Affects Versions:
2.5
Assignee:
Andrea Aime
Created:
28/Aug/14 4:54 AM
Environment:
PostgreSQL 9.1
PostGIS 2.1.1
Priority:
MinorMinor
Reporter:
fran peru?i?
Bug is visible when using ‘id IN (1,2,3)’ CQL filter on the view layer.
When filtering a normal layer (not created by the view) by mention CQL filter everything works as expected. However, when using the same filter on the view layer all the items are filtered, not a single feature is viible on the layer.
One workaround to this issue is to use a OR comparator (id=1 OR id = 2), the other one is to reneme the ‘id’ property (gid IN (1,2))
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
