[Geoserver-devel] [jira] (GEOS-6636) DELETE recurse=true consistenecy
Jody Garnett created an issue
GeoServer / BugGEOS-6636
Issue Type:
BugBug
Assignee:
Andrea Aime
Created:
28/Aug/14 5:59 PM
Priority:
MajorMajor
Reporter:
Jody Garnett
The operation of DELETE layer and DELETE featureType are not consistent.
This is the first of two issues created as a follow up to GEOS-6575 and GEOS-6575. These issues describe the use of the REST api to kick GeoServer into noticing when new columns have been added to a PostGIS database.
The use of DELETE featureType recurse=true resets the DataStore connection in order to clear the cache of attributes.
  • Previously the DataStore “reset” was implemented using DataStore.dispose() followed by creating a new DataStore - resulting in the failure of concurrent described in GEOS-6575.
  • The use of DataStore “reset” now makes use of ContentEntry.flush() if available as described in GEOS-6616
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
