[Geoserver-devel] [jira] (GEOS-6637) PUSH FeatureType?refreshAttributes=true
Jody Garnett created an issue
GeoServer / BugGEOS-6637
Issue Type:
BugBug
Assignee:
Andrea Aime
Components:
REST
Created:
28/Aug/14 7:33 PM
Priority:
MajorMajor
Reporter:
Jody Garnett
Used to refresh a FeatureType (for example when a new column is added to a PostGIS table)
Functionally this request is similar to recalculate options already provided to refresh bounds information.
Propose refreshAttributes with:
  • flush: clears attribute information from resource pool (and ContentEntry if available)
  • reset: force dispose of DataStore and reconnection
As described in GEOS-6636 DELETE featureType is being used to force GeoServer to clear any cached state associated with a FeaturerType - and then the FeatureType is being recreated from scratch just so a “fresh” list of attributes is obtained. This workflow has introduced problems around the DataStore being “reset” (disposed and created) to avoid attributes cached at the GeoTools level.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
