Danny Cheng created an issue |
Issue Type: |
Bug |
Assignee: |
Created: |
03/Sep/14 12:34 PM |
Priority: |
Major |
Reporter: |
If a CAS filter is configured, the logout button on the GeoServer UI will also trigger CAS logout when clicked regardless if CAS logout URL is configured. There should be a separate option in the CAS filter to indicate if the web UI logout button should also trigger CAS logout. This is desired because if single logout is configured in CAS, you don’t want GeoServer UI to log out of other CAS clients too. |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
