[Geoserver-devel] [jira] (GEOS-6679) WCS20 GetCoverage multipart does encoding 2 times
Daniele Romagnoli created an issue
GeoServer / BugGEOS-6679
Issue Type:
BugBug
Affects Versions:
2.6-RC1
Assignee:
Andrea Aime
Components:
WCS
Created:
17/Sep/14 5:10 AM
Fix Versions:
2.6-RC2, 2.7-beta
Priority:
MinorMinor
Reporter:
Daniele Romagnoli
The WCS20GetCoverageMultipartResponse does encoding 2 times:
the write method has this piece of code:
BodyPart coveragePart = new MimeBodyPart();
CoverageEncoder encoder = new CoverageEncoder(delegate, coverage, format, encodingParameters);
coveragePart.setDataHandler(new DataHandler(encoder, “geoserver/coverageDelegate”));
multipart.addBodyPart(coveragePart);
// write out the multipart (we need to use mime message trying to
// encode directly with multipart or BodyPart does not set properly
// the encodings and binary files gets ruined
MimeMessage message = new GeoServerMimeMessage();
message.setContent(multipart);
message.writeTo(output);
output.flush();
delegate.encode(coverage, format, encodingParameters, output);
Which results in 2 encodings:
  1. message.writeTo(output)
  2. delegate.encode(…)
I guess the last delegate.encode(…) has been forgotten here by mistake.
Also note that WCSMultipartResponse has very similar MimeMessaging based encoding code without the second delegate.encode invocation (since it’s internally called by the message.writeTo(output) ) …
Even removing that last encode, a JPEG multipart test still works so it should be safe to be removed.
Pull request incoming…
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
