[Geoserver-devel] [jira] (GEOS-6692) multidimensional output in WCS 2.0 only supports WGS84 subsetting
Jeroen Dries created an issue
GeoServer / BugGEOS-6692
Issue Type:
BugBug
Affects Versions:
2.6-RC1
Assignee:
Andrea Aime
Components:
WCS
Created:
29/Sep/14 8:49 AM
Priority:
MajorMajor
Reporter:
Jeroen Dries
Using a multidimensional output format with WCS 2.0 on does not work when trying to subset using coordinates other than lon/lat.
This is caused by WCSDimensionsSubsetHelper#filterSpatial, which assumes that the request envelope is using lon/lat.
I will add a pull request for a patch, with unit test.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
