Carsten Klein created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.6.0 |
Assignee: |
Components: |
PostGIS |
Created: |
07/Oct/14 1:25 AM |
Priority: |
Critical |
Reporter: |
I just upgraded from version 2.5.2 to 2.6.0 and encountered, that GeoServer 2.6.0 now leaves pending/open transactions in the PostGIS/PostgreSQL database between service requests. I’m using a JNDI PostGIS data source (configured in Apache Tomcat) and did not test whether this happens with non-JNDI data sources too (however, I’m sure it has nothing to do with JNDI or non-JNDI sources). GeoServer/GeoTools seems to start transaction even if it’s only reading data (that is, not performing a WFS-T operation, but processing a WMS request). Maybe you start the transaction “manually” or it’s the However, before the connection is given back to the pool (aka closed), there is no longer a Actually, GeoServer 2.5.2 issued a Maybe a |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
