[Geoserver-devel] [jira] (GEOS-6723) Error Using the Pregeneralized Features module on Geoserver
Joel Schmitt created an issue
GeoServer / BugGEOS-6723
Issue Type:
BugBug
Affects Versions:
2.5.1
Assignee:
Andrea Aime
Components:
Features pregeneralized
Created:
13/Oct/14 11:05 AM
Priority:
MajorMajor
Reporter:
Joel Schmitt
I am trying to use the pregeneralized features extension for limiting the number of vertices drawn for a large dataset that resides in PostGIS (geometry type ‘MultiLineString’). I’ve been through the tutorials and the help forums and adjusted my .xml config file in many different ways according to all the info I’ve found. I have also set up my Generalizing Data Store on geoserver in the exact manner that was specified in this tutorial:
http://osgeo-org.1560.x6.nabble.com/attachment/3819796/0/pregen_tutorial.html
After zooming and panning around in OpenLayers, I am still receiving the following message in the geoserver logs:
“2014-10-08 10:00:10,973 WARN [org.geotools.data.gen] - No hint for geometry distance in query, fallback to base feature”
From my understanding, this means that something in the config file is not right and geoserver is defaulting to the base “the_geom” column for rendering the pipelines.
Here is my .xml file:
<?xml version=“1.0” encoding=“UTF-8”?>
<GeneralizationInfos version=“1.0”>
<GeneralizationInfo dataSourceNameSpace=“pipelines_pregen” dataSourceName=“pipelines”
featureName=“pipelines_general_tx_1” baseFeatureName=“domestic_pipelines_tx_1” geomPropertyName=“the_geom”>
<Generalization distance=“5000” featureName=“domestic_pipelines_tx_1” geomPropertyName=“the_geom5000”/>
</GeneralizationInfo>
</GeneralizationInfos>
I’ve checked and all the parameters are populated correctly in the xml file according to the guidelines laid out in this thread:
http://osgeo-org.1560.x6.nabble.com/New-postgis-feature-pregeneralized-tutorial-question-tp3797025p3797026.html
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
