[Geoserver-devel] [jira] (GEOS-6768) externalGraphic with relative path and query parameters problem
Tobias Warneke created an issue
GeoServer / BugGEOS-6768
Issue Type:
BugBug
Affects Versions:
2.6.1
Assignee:
Andrea Aime
Created:
18/Nov/14 2:47 AM
Priority:
MajorMajor
Reporter:
Tobias Warneke
I don’t know, if this should be here or in GeoTools Issues.
I implemented a ExternalGraphicFactory which is working. (getIcon gets called). So I wanted to provide some additional parameters using the URL of my online resource.
Here are the tests I did.
myimage.png -> worked
<absolute-path>/myimage.png?param=testparam –> worked
and this is my hack at the moment for relative paths:
myimage.png&param=testparam –> work (path and parameter separated by a &)
Here is the snipped of my external graphics:
<ExternalGraphic>
<OnlineResource xlink:href=“myimage.png” />
<Format>myformat</Format>
</ExternalGraphic>
The logging does say:
18 Nov 09:43:46 DEBUG [geotools.styling] - Looks like myimage.png?param=testparam is a relative path…
Here the parameter is still there but in my factory class the param - part is not there.
However, this is not a problem with GeoServer 2.3, 2.5.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
