[Geoserver-devel] [jira] (GEOS-6779) Test failure on netcdf-out build
Brad Hards created an issue
GeoServer / BugGEOS-6779
Issue Type:
BugBug
Affects Versions:
2.7-beta
Assignee:
Andrea Aime
Components:
Community modules
Created:
20/Nov/14 4:09 PM
Environment:
java version “1.7.0_72”
Java™ SE Runtime Environment (build 1.7.0_72-b14)
Java HotSpot™ 64-Bit Server VM (build 24.72-b04, mixed mode)
Ubuntu 14.04
Priority:
MajorMajor
Reporter:
Brad Hards
Executing “mvn clean install” on a git checkout of master from today (as of 23539377421cf4ee1bcfd092ff661b2e2fccbcc7) from the command line produces:
[INFO] Scanning for projects...
[INFO]
[INFO] Building WCS NetCDF output Module 2.7-SNAPSHOT
Downloading: http://repo.boundlessgeo.com/main/org/slf4j/slf4j-log4j12/1.6.4/slf4j-log4j12-1.6.4.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/slf4j/slf4j-log4j12/1.6.4/slf4j-log4j12-1.6.4.pom
Downloading: http://maven.restlet.org/org/slf4j/slf4j-log4j12/1.6.4/slf4j-log4j12-1.6.4.pom
Downloading: http://repo.maven.apache.org/maven2/org/slf4j/slf4j-log4j12/1.6.4/slf4j-log4j12-1.6.4.pom
Downloaded: http://repo.maven.apache.org/maven2/org/slf4j/slf4j-log4j12/1.6.4/slf4j-log4j12-1.6.4.pom (2 KB at 2.8 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.pom
Downloading: http://maven.restlet.org/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.pom
Downloading: http://repo.maven.apache.org/maven2/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.pom
Downloaded: http://repo.maven.apache.org/maven2/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.pom (3 KB at 7.1 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-jts-wrapper/13-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/13-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/13-SNAPSHOT/maven-metadata.xml (971 B at 1.2 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/13-SNAPSHOT/gt-jts-wrapper-13-20141118.095332-64.pom
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/13-SNAPSHOT/gt-jts-wrapper-13-20141118.095332-64.pom (4 KB at 6.7 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/slf4j/slf4j-log4j12/1.6.4/slf4j-log4j12-1.6.4.jar
Downloading: http://repo.boundlessgeo.com/main/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.jar
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/13-SNAPSHOT/gt-jts-wrapper-13-20141118.095332-64.jar
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-jts-wrapper/13-SNAPSHOT/gt-jts-wrapper-13-20141118.095332-64.jar (81 KB at 55.3 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/slf4j/slf4j-log4j12/1.6.4/slf4j-log4j12-1.6.4.jar
Downloading: http://download.osgeo.org/webdav/geotools/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.jar
Downloading: http://maven.restlet.org/org/slf4j/slf4j-log4j12/1.6.4/slf4j-log4j12-1.6.4.jar
Downloading: http://maven.restlet.org/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.jar
Downloading: http://repo.maven.apache.org/maven2/org/slf4j/slf4j-log4j12/1.6.4/slf4j-log4j12-1.6.4.jar
Downloading: http://repo.maven.apache.org/maven2/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.jar
Downloaded: http://repo.maven.apache.org/maven2/org/slf4j/slf4j-log4j12/1.6.4/slf4j-log4j12-1.6.4.jar (10 KB at 25.3 KB/sec)
Downloaded: http://repo.maven.apache.org/maven2/org/slf4j/slf4j-api/1.6.4/slf4j-api-1.6.4.jar (26 KB at 35.1 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-netcdf-out ---
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-netcdf-out ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-netcdf-out ---
[INFO] [GitCommitIdMojo] Running on '/home/bradh/geoserver/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Have the artifact store work with a NIO lock directory inside GEOSERVER_DATA_DIR/tmp
[INFO] [GitCommitIdMojo] build.build.user.email = bradh@anonymised.com
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 21.11.2014 @ 00:57:15 EST
[INFO] [GitCommitIdMojo] build.timestamp = 21-Nov-2014 08:39
[INFO] [GitCommitIdMojo] build.build.time = 21.11.2014 @ 08:39:51 EST
[INFO] [GitCommitIdMojo] build.branch = master
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.build.user.name = Brad Hards
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2353937
[INFO] [GitCommitIdMojo] build.commit.id = 23539377421cf4ee1bcfd092ff661b2e2fccbcc7
[INFO] [GitCommitIdMojo] build.commit.message.full = Have the artifact store work with a NIO lock directory inside GEOSERVER_DATA_DIR/tmp
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-netcdf-out ---
[INFO] Copying 1 resource
[INFO] Copying 6 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-netcdf-out ---
[INFO] Compiling 4 source files to /home/bradh/geoserver/src/community/netcdf-out/target/classes
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-netcdf-out ---
[INFO] Copying 4 resources
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-netcdf-out ---
[INFO] Compiling 6 source files to /home/bradh/geoserver/src/community/netcdf-out/target/test-classes
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-netcdf-out ---
[INFO] Surefire report directory: /home/bradh/geoserver/src/community/netcdf-out/target/surefire-reports
 T E S T S
Running org.geoserver.wcs2_0.WCSMultiDimSubsetTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
21 Nov 08:40:45 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Fri Nov 21 08:40:45 EST 2014]; root of context hierarchy
21 Nov 08:40:45 INFO [test.GeoServerTestApplicationContext] - Bean 'nullLockProvider' of type [class org.geoserver.platform.resource.NullLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:45 INFO [test.GeoServerTestApplicationContext] - Bean 'lockProvider' of type [class org.geoserver.platform.resource.GlobalLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:45 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceStore' of type [class org.geoserver.platform.resource.DataDirectoryResourceStore] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:45 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' of type [class org.geoserver.platform.GeoServerResourceLoader] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:45 INFO [test.GeoServerTestApplicationContext] - Bean 'wcs111Service' of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:46 INFO [test.GeoServerTestApplicationContext] - Bean 'wcs20Service' of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:46 INFO [test.GeoServerTestApplicationContext] - Bean 'extensions' of type [class org.geoserver.platform.GeoServerExtensions] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:46 INFO [test.GeoServerTestApplicationContext] - Bean 'dataDirectory' of type [class org.geoserver.config.GeoServerDataDirectory] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:46 INFO [test.GeoServerTestApplicationContext] - Bean 'authenticationManager' of type [class org.geoserver.security.GeoServerSecurityManager] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:46 INFO [org.geoserver] - Loaded style 'Default'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded style 'raster'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded default workspace gs
21 Nov 08:40:46 INFO [org.geoserver] - Loaded workspace 'cite'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded workspace 'cgf'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded workspace 'cdf'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded workspace 'wcs'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded workspace 'sf'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded workspace 'gs'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded coverage store 'multiband'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded coverage 'multiband'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded layer 'multiband'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded coverage store 'DEM'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded coverage 'DEM'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded layer 'DEM'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded coverage store 'World'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded coverage 'World'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded layer 'World'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded coverage store 'RotatedCad'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded coverage 'RotatedCad'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded layer 'RotatedCad'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded coverage store 'BlueMarble'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded coverage 'BlueMarble'
21 Nov 08:40:46 INFO [org.geoserver] - Loaded layer 'BlueMarble'
21 Nov 08:40:47 INFO [org.geoserver] - Loaded service 'WCSInfoImpl-3adf1891:149cf26686c:-7fdf', enabled
21 Nov 08:40:47 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler 'dispatcher'
21 Nov 08:40:47 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler 'dispatcher'
21 Nov 08:40:47 INFO [org.geoserver] - GeoServer configuration lock is enabled
21 Nov 08:40:47 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler 'dispatcher'
21 Nov 08:40:47 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler 'dispatcher'
21 Nov 08:40:47 INFO [geoserver.security] - Start security migration
21 Nov 08:40:47 INFO [geoserver.security] - Information regarding the master password is in: /home/bradh/geoserver/src/community/netcdf-out/target/default1962763317424138773data/security/masterpw.info
21 Nov 08:40:48 WARN [geoserver.security] - Strong cryptography is NOT available
Download and installation the of unlimted length policy files is recommended
21 Nov 08:40:48 INFO [geoserver.security] - Start reloading user/groups for service named default
21 Nov 08:40:48 INFO [geoserver.security] - Reloading user/groups successful for service named default
21 Nov 08:40:48 WARN [geoserver.security] - Cannot find: /accessDenied.jsp
21 Nov 08:40:49 WARN [geoserver.security] - Cannot find: /accessDenied.jsp
21 Nov 08:40:49 INFO [geoserver.security] - Start encrypting configuration passwords using pbePasswordEncoder
21 Nov 08:40:49 INFO [geoserver.security] - End encrypting configuration passwords
21 Nov 08:40:49 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
21 Nov 08:40:49 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
21 Nov 08:40:49 INFO [security.xml] - Successful lock: /home/bradh/geoserver/src/community/netcdf-out/target/default1962763317424138773data/security/usergroup/default/users.xml.lock
21 Nov 08:40:49 INFO [security.xml] - Successful lock: /home/bradh/geoserver/src/community/netcdf-out/target/default1962763317424138773data/security/role/default/roles.xml.lock
21 Nov 08:40:49 INFO [geoserver.security] - Start storing roles for service named default
21 Nov 08:40:49 INFO [geoserver.security] - Storing roles successful for service named default
21 Nov 08:40:49 INFO [geoserver.security] - Start reloading roles for service named default
21 Nov 08:40:49 INFO [geoserver.security] - Reloading roles successful for service named default
21 Nov 08:40:49 INFO [geoserver.security] - Adjusted last modified for file: security/role/default/roles.xml
21 Nov 08:40:49 INFO [geoserver.security] - Start storing user/groups for service named default
21 Nov 08:40:49 INFO [geoserver.security] - Storing user/groups successful for service named default
21 Nov 08:40:49 INFO [geoserver.security] - Start reloading user/groups for service named default
21 Nov 08:40:49 INFO [geoserver.security] - Reloading user/groups successful for service named default
21 Nov 08:40:49 INFO [geoserver.security] - Adjusted last modified for file: security/usergroup/default/users.xml
21 Nov 08:40:49 INFO [geoserver.security] - End security migration
21 Nov 08:40:52 WARN [imagemosaic.catalog] - This granule catalog was not properly dispose as it still points to:ServiceInfo
 description=Features from ShapefileDataStore
21 Nov 08:40:52 INFO [geoserver.wcs] -
Request: getServiceInfo
21 Nov 08:40:53 INFO [wcs2_0.util] -  Examining encoded name wcs__lambert
21 Nov 08:40:53 INFO [wcs2_0.util] -  Checking pair wcs : lambert
21 Nov 08:40:53 INFO [wcs2_0.util] -  - Namespace found wcs
21 Nov 08:40:53 INFO [wcs2_0.util] -  - Collecting layer wcs:lambert
Error: Could not find mediaLib accelerator wrapper classes. Continuing in pure Java mode.
Occurs in: com.sun.media.jai.mlib.MediaLibAccessor
java.lang.NoClassDefFoundError: com/sun/medialib/mlib/Image
        at com.sun.media.jai.mlib.MediaLibAccessor$1.run(MediaLibAccessor.java:248)
        at java.security.AccessController.doPrivileged(Native Method)
        at com.sun.media.jai.mlib.MediaLibAccessor.setUseMlib(MediaLibAccessor.java:245)
        at com.sun.media.jai.mlib.MediaLibAccessor.useMlib(MediaLibAccessor.java:177)
        at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:357)
        at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:315)
        at com.sun.media.jai.mlib.MlibScaleRIF.create(MlibScaleRIF.java:67)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
        at java.lang.reflect.Method.invoke(Method.java:606)
        at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
        at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
        at javax.media.jai.ThreadSafeOperationRegistry.invokeFactory(ThreadSafeOperationRegistry.java:473)
        at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
        at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
        at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
        at javax.media.jai.RenderedOp.getRendering(RenderedOp.java:888)
        at javax.media.jai.RenderedOp$1.getPropertyNames(RenderedOp.java:1791)
        at javax.media.jai.PropertyEnvironment.mapDefaults(PropertyEnvironment.java:270)
        at javax.media.jai.PropertyEnvironment.getPropertyNames(PropertyEnvironment.java:125)
        at javax.media.jai.WritablePropertySourceImpl.addProperties(WritablePropertySourceImpl.java:298)
        at javax.media.jai.RenderedOp.createPropertySource(RenderedOp.java:1817)
        at javax.media.jai.RenderedOp.getProperty(RenderedOp.java:1968)
        at org.geotools.gce.imagemosaic.GranuleDescriptor$GranuleLoadingResult.<init>(GranuleDescriptor.java:257)
        at org.geotools.gce.imagemosaic.GranuleDescriptor.loadRaster(GranuleDescriptor.java:929)
        at org.geotools.gce.imagemosaic.GranuleLoader.call(GranuleLoader.java:110)
        at org.geotools.gce.imagemosaic.GranuleLoader.call(GranuleLoader.java:41)
        at java.util.concurrent.FutureTask.run(FutureTask.java:262)
        at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.accept(RasterLayerResponse.java:406)
        at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.access$2200(RasterLayerResponse.java:340)
        at org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.visit(RasterLayerResponse.java:1017)
        at org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog$1.visit(CachingDataStoreGranuleCatalog.java:192)
        at org.geotools.data.store.ContentFeatureSource.accepts(ContentFeatureSource.java:696)
        at org.geotools.data.store.ContentFeatureCollection.accepts(ContentFeatureCollection.java:120)
        at org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog.getGranuleDescriptors(CachingDataStoreGranuleCatalog.java:158)
        at org.geotools.gce.imagemosaic.RasterManager.getGranuleDescriptors(RasterManager.java:1153)
        at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1339)
        at org.geotools.gce.imagemosaic.RasterLayerResponse.processRequest(RasterLayerResponse.java:1228)
        at org.geotools.gce.imagemosaic.RasterLayerResponse.createResponse(RasterLayerResponse.java:1194)
        at org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:1143)
        at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:863)
        at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:842)
        at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:776)
        at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:227)
        at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:217)
        at org.geoserver.wcs2_0.util.RequestUtils.readBestCoverage(RequestUtils.java:242)
        at org.geoserver.wcs2_0.GetCoverage.readCoverage(GetCoverage.java:916)
        at org.geoserver.wcs2_0.GetCoverage.readCoverage(GetCoverage.java:757)
        at org.geoserver.wcs2_0.GetCoverage.setupCoverage(GetCoverage.java:338)
        at org.geoserver.wcs2_0.GetCoverage.run(GetCoverage.java:263)
        at org.geoserver.wcs2_0.DefaultWebCoverageService20.getCoverage(DefaultWebCoverageService20.java:119)
        at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
        at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
        at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
        at com.sun.proxy.$Proxy33.getCoverage(Unknown Source)
        at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:839)
        at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:280)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
        at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1421)
        at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
        at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1440)
        at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1375)
        at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:924)
        at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:907)
        at org.geoserver.wcs2_0.WCSMultiDimSubsetTest.sliceLambert(WCSMultiDimSubsetTest.java:73)
Caused by: java.lang.ClassNotFoundException: com.sun.medialib.mlib.Image
        at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
        at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
        ... 119 more
21 Nov 08:40:53 INFO [geoserver.wcs] -
Request: getCoverage
    extension:
    service = WCS
    version = 2.0.1
    baseUrl = http://localhost:8080/geoserver/
    coverageId = wcs__lambert
    dimensionSubsetGroup[0] = wcs:dimensionSubset=net.opengis.wcs20.impl.DimensionTrimTypeImpl@anonymised.com (dimension: E, cRS: http://www.opengis.net/def/crs/EPSG/0/31300) (trimLow: 135908.00953210733, trimHigh: 135933.00953210733)dimensionSubsetGroup[0] = wcs:dimensionSubset=net.opengis.wcs20.impl.DimensionTrimTypeImpl@anonymised.com (dimension: N, cRS: http://www.opengis.net/def/crs/EPSG/0/31300) (trimLow: 217515.44099086802, trimHigh: 217540.44099086802)
    dimensionSubset[0]:
        dimension = E
        cRS = http://www.opengis.net/def/crs/EPSG/0/31300
        trimLow = 135908.00953210733
        trimHigh = 135933.00953210733dimensionSubset[0]:
        dimension = N
        trimLow = 217515.44099086802
        trimHigh = 217540.44099086802
    format = application/custom
21 Nov 08:40:53 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Fri Nov 21 08:40:45 EST 2014]; root of context hierarchy
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 53.896 sec
Running org.geoserver.wcs2_0.WCSNetCDFMosaicTest
21 Nov 08:40:53 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Fri Nov 21 08:40:53 EST 2014]; root of context hierarchy
21 Nov 08:40:54 INFO [test.GeoServerTestApplicationContext] - Bean 'nullLockProvider' of type [class org.geoserver.platform.resource.NullLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:54 INFO [test.GeoServerTestApplicationContext] - Bean 'lockProvider' of type [class org.geoserver.platform.resource.GlobalLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:54 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceStore' of type [class org.geoserver.platform.resource.DataDirectoryResourceStore] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:54 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' of type [class org.geoserver.platform.GeoServerResourceLoader] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:54 INFO [test.GeoServerTestApplicationContext] - Bean 'wcs111Service' of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:54 INFO [test.GeoServerTestApplicationContext] - Bean 'wcs20Service' of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:54 INFO [test.GeoServerTestApplicationContext] - Bean 'extensions' of type [class org.geoserver.platform.GeoServerExtensions] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:54 INFO [test.GeoServerTestApplicationContext] - Bean 'dataDirectory' of type [class org.geoserver.config.GeoServerDataDirectory] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:54 INFO [test.GeoServerTestApplicationContext] - Bean 'authenticationManager' of type [class org.geoserver.security.GeoServerSecurityManager] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:40:54 INFO [org.geoserver] - Loaded style 'Default'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded style 'raster'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded default workspace gs
21 Nov 08:40:54 INFO [org.geoserver] - Loaded workspace 'cite'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded workspace 'cgf'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded workspace 'cdf'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded workspace 'wcs'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded workspace 'sf'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded workspace 'gs'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded coverage store 'multiband'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded coverage 'multiband'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded layer 'multiband'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded coverage store 'DEM'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded coverage 'DEM'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded layer 'DEM'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded coverage store 'World'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded coverage 'World'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded layer 'World'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded coverage store 'RotatedCad'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded coverage 'RotatedCad'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded layer 'RotatedCad'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded coverage store 'BlueMarble'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded coverage 'BlueMarble'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded layer 'BlueMarble'
21 Nov 08:40:54 INFO [org.geoserver] - Loaded service 'WCSInfoImpl-3adf1891:149cf26686c:-7fa6', enabled
21 Nov 08:40:54 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler 'dispatcher'
21 Nov 08:40:54 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler 'dispatcher'
21 Nov 08:40:54 INFO [org.geoserver] - GeoServer configuration lock is enabled
21 Nov 08:40:54 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler 'dispatcher'
21 Nov 08:40:54 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler 'dispatcher'
21 Nov 08:40:55 INFO [geoserver.security] - Start security migration
21 Nov 08:40:55 INFO [geoserver.security] - Information regarding the master password is in: /home/bradh/geoserver/src/community/netcdf-out/target/default8095533628199835893data/security/masterpw.info
21 Nov 08:40:55 WARN [geoserver.security] - Strong cryptography is NOT available
21 Nov 08:40:55 INFO [geoserver.security] - Start reloading user/groups for service named default
21 Nov 08:40:55 INFO [geoserver.security] - Reloading user/groups successful for service named default
21 Nov 08:40:55 WARN [geoserver.security] - Cannot find: /accessDenied.jsp
21 Nov 08:40:55 INFO [geoserver.security] - Start encrypting configuration passwords using pbePasswordEncoder
21 Nov 08:40:55 INFO [geoserver.security] - End encrypting configuration passwords
21 Nov 08:40:55 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
21 Nov 08:40:55 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
21 Nov 08:40:55 INFO [security.xml] - Successful lock: /home/bradh/geoserver/src/community/netcdf-out/target/default8095533628199835893data/security/usergroup/default/users.xml.lock
21 Nov 08:40:55 INFO [security.xml] - Successful lock: /home/bradh/geoserver/src/community/netcdf-out/target/default8095533628199835893data/security/role/default/roles.xml.lock
21 Nov 08:40:55 INFO [geoserver.security] - Start storing roles for service named default
21 Nov 08:40:55 INFO [geoserver.security] - Storing roles successful for service named default
21 Nov 08:40:55 INFO [geoserver.security] - Start reloading roles for service named default
21 Nov 08:40:55 INFO [geoserver.security] - Reloading roles successful for service named default
21 Nov 08:40:55 INFO [geoserver.security] - Adjusted last modified for file: security/role/default/roles.xml
21 Nov 08:40:55 INFO [geoserver.security] - Start storing user/groups for service named default
21 Nov 08:40:55 INFO [geoserver.security] - Storing user/groups successful for service named default
21 Nov 08:40:55 INFO [geoserver.security] - Adjusted last modified for file: security/usergroup/default/users.xml
21 Nov 08:40:55 INFO [geoserver.security] - End security migration
21 Nov 08:40:56 WARN [imagemosaic.Utils] - Unable to find sample image for path /home/bradh/geoserver/src/community/netcdf-out/./target/default8095533628199835893data/2DLatLonCoverage/sample_image
21 Nov 08:40:56 WARN [gce.imagemosaic] - Unable to find sample image for path file:/home/bradh/geoserver/src/community/netcdf-out/./target/default8095533628199835893data/2DLatLonCoverage/datastore.properties
21 Nov 08:41:00 WARN [geoserver.catalog] - MultiInputs BandMerge operation unavailable. Band Merge will be made through standard JAI BandMerge operations:
 No such "BandMergeOp" operation for this processor.
21 Nov 08:41:01 INFO [geoserver.wcs] -
21 Nov 08:41:01 INFO [wcs2_0.util] -  Examining encoded name wcs__dummyView
21 Nov 08:41:01 INFO [wcs2_0.util] -  Checking pair wcs : dummyView
21 Nov 08:41:01 INFO [wcs2_0.util] -  - Namespace found wcs
21 Nov 08:41:01 INFO [wcs2_0.util] -  - Collecting layer wcs:dummyView
    extension:
    service = WCS
    version = 2.0.1
    coverageId = wcs__dummyView
    dimensionSubsetGroup[0] = wcs:dimensionSubset=net.opengis.wcs20.impl.DimensionSliceTypeImpl@anonymised.com (dimension: http://www.opengis.net/def/axis/OGC/0/time, cRS: null) (slicePoint: 2013-01-08T00:00:00.000Z)
    dimensionSubset[0]:
        dimension = http://www.opengis.net/def/axis/OGC/0/time
        slicePoint = 2013-01-08T00:00:00.000Z
    format = application/x-netcdf
21 Nov 08:41:01 INFO [wcs2_0.util] -  Examining encoded name wcs__2DLatLonCoverage
21 Nov 08:41:01 INFO [wcs2_0.util] -  Checking pair wcs : 2DLatLonCoverage
21 Nov 08:41:01 INFO [wcs2_0.util] -  - Collecting layer wcs:2DLatLonCoverage
21 Nov 08:41:01 WARN [imagemosaic.Utils] - Unable to find sample image for path /home/bradh/geoserver/src/community/netcdf-out/./target/default8095533628199835893data/2DLatLonCoverage/sample_image
21 Nov 08:41:01 WARN [gce.imagemosaic] - Unable to find sample image for path file:/home/bradh/geoserver/src/community/netcdf-out/./target/default8095533628199835893data/2DLatLonCoverage/datastore.properties
21 Nov 08:41:03 INFO [geoserver.wcs] -
    extension:
    service = WCS
    version = 2.0.1
    coverageId = wcs__2DLatLonCoverage
    dimensionSubsetGroup[0] = wcs:dimensionSubset=net.opengis.wcs20.impl.DimensionSliceTypeImpl@anonymised.com (dimension: time, cRS: http://www.opengis.net/def/trs/ISO-8601/0/Gregorian UTC) (slicePoint: 2013-11-01T00:00:00.000Z)dimensionSubsetGroup[0] = wcs:dimensionSubset=net.opengis.wcs20.impl.DimensionSliceTypeImpl@anonymised.com (dimension: BANDS, cRS: null) (slicePoint: MyBand)
    dimensionSubset[0]:
        dimension = time
        cRS = http://www.opengis.net/def/trs/ISO-8601/0/Gregorian UTC
        slicePoint = 2013-11-01T00:00:00.000ZdimensionSubset[0]:
        dimension = BANDS
        slicePoint = MyBand
GeneralEnvelope[(10.0, 40.0), (55.0, 70.0)]
21 Nov 08:41:03 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Fri Nov 21 08:40:53 EST 2014]; root of context hierarchy
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 9.778 sec <<< FAILURE!
testRequestCoverage(org.geoserver.wcs2_0.WCSNetCDFMosaicTest)  Time elapsed: 1408 sec  <<< FAILURE!
java.lang.AssertionError: expected:<45.0> but was:<30.0>
        at org.junit.Assert.fail(Assert.java:88)
        at org.junit.Assert.failNotEquals(Assert.java:743)
        at org.junit.Assert.assertEquals(Assert.java:494)
        at org.junit.Assert.assertEquals(Assert.java:592)
        at org.geoserver.wcs2_0.WCSNetCDFMosaicTest.testRequestCoverage(WCSNetCDFMosaicTest.java:114)
Running org.geoserver.wcs2_0.WCSNetCDFTest
21 Nov 08:41:04 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Fri Nov 21 08:41:04 EST 2014]; root of context hierarchy
21 Nov 08:41:04 INFO [test.GeoServerTestApplicationContext] - Bean 'nullLockProvider' of type [class org.geoserver.platform.resource.NullLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:41:04 INFO [test.GeoServerTestApplicationContext] - Bean 'lockProvider' of type [class org.geoserver.platform.resource.GlobalLockProvider] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:41:04 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceStore' of type [class org.geoserver.platform.resource.DataDirectoryResourceStore] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:41:04 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' of type [class org.geoserver.platform.GeoServerResourceLoader] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:41:04 INFO [test.GeoServerTestApplicationContext] - Bean 'wcs111Service' of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:41:04 INFO [test.GeoServerTestApplicationContext] - Bean 'wcs20Service' of type [class org.springframework.aop.framework.ProxyFactoryBean] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:41:04 INFO [test.GeoServerTestApplicationContext] - Bean 'extensions' of type [class org.geoserver.platform.GeoServerExtensions] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:41:04 INFO [test.GeoServerTestApplicationContext] - Bean 'dataDirectory' of type [class org.geoserver.config.GeoServerDataDirectory] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:41:04 INFO [test.GeoServerTestApplicationContext] - Bean 'authenticationManager' of type [class org.geoserver.security.GeoServerSecurityManager] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'Default'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'MapNeatline'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'Bridges'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'Buildings'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'NamedPlaces'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'BasicPolygons'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'Streams'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'Forests'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'Ponds'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'raster'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'DividedRoutes'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'RoadSegments'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded style 'Lakes'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded default workspace gs
21 Nov 08:41:05 INFO [org.geoserver] - Loaded workspace 'cite'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded workspace 'cgf'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded workspace 'cdf'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded workspace 'wcs'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded workspace 'sf'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded workspace 'gs'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded data store 'cite'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded feature type 'cite'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Forests'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Ponds'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Geometryless'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Buildings'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'MapNeatline'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'NamedPlaces'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'DividedRoutes'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Streams'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Bridges'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'BasicPolygons'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'RoadSegments'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Lakes'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded data store 'cgf'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded feature type 'cgf'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Points'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Polygons'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'MPoints'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Lines'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'MLines'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'MPolygons'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded data store 'cdf'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded feature type 'cdf'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Other'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Seven'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Inserts'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Nulls'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Locks'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Updates'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Fifteen'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'Deletes'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage store 'usa'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage 'usa'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'usa'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage store 'multiband'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage 'multiband'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'multiband'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage store 'DEM'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage 'DEM'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'DEM'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage store 'World'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage 'World'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'World'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage store 'RotatedCad'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage 'RotatedCad'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'RotatedCad'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage store 'BlueMarble'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded coverage 'BlueMarble'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'BlueMarble'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded data store 'sf'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded feature type 'sf'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'GenericEntity'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'PrimitiveGeoFeature'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded layer 'AggregateGeoFeature'
21 Nov 08:41:05 INFO [org.geoserver] - Loaded service 'WCSInfoImpl-3adf1891:149cf26686c:-7efe', enabled
21 Nov 08:41:05 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler 'dispatcher'
21 Nov 08:41:05 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler 'dispatcher'
21 Nov 08:41:05 INFO [org.geoserver] - GeoServer configuration lock is enabled
21 Nov 08:41:05 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler 'dispatcher'
21 Nov 08:41:05 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler 'dispatcher'
21 Nov 08:41:06 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
21 Nov 08:41:06 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
21 Nov 08:41:06 WARN [geoserver.security] - Strong cryptography is NOT available
21 Nov 08:41:06 INFO [geoserver.security] - Start reloading user/groups for service named default
21 Nov 08:41:06 INFO [geoserver.security] - Reloading user/groups successful for service named default
21 Nov 08:41:06 INFO [geoserver.security] - Start encrypting configuration passwords using pbePasswordEncoder
21 Nov 08:41:06 INFO [geoserver.security] - End encrypting configuration passwords
21 Nov 08:41:07 INFO [geoserver.wcs] -
21 Nov 08:41:07 INFO [wcs2_0.util] -  Examining encoded name wcs__NO2
21 Nov 08:41:07 INFO [wcs2_0.util] -  Checking pair wcs : NO2
21 Nov 08:41:07 INFO [wcs2_0.util] -  - Namespace found wcs
21 Nov 08:41:07 INFO [wcs2_0.util] -  - Collecting layer wcs:NO2
21 Nov 08:41:08 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: This request is trying to read too much data, the limit is 40KB but the actual amount of bytes to be read is 45KB
        at org.geoserver.wcs2_0.GetCoverage$ImageSizeRecorder.isSizeExceeded(GetCoverage.java:1514)
        at org.geoserver.wcs2_0.GetCoverage$ImageSizeRecorder.addSize(GetCoverage.java:1500)
        at org.geoserver.wcs2_0.GetCoverage.readCoverage(GetCoverage.java:930)
        at org.geoserver.wcs2_0.GetCoverage.run(GetCoverage.java:282)
        at org.geoserver.wcs2_0.WCSNetCDFTest.testInputMemoryExceeded(WCSNetCDFTest.java:134)
21 Nov 08:41:08 WARN [geoserver.ows] - OWS20SEH: handling org.vfny.geoserver.wcs.WcsException: This request is trying to read too much data, the limit is 40KB but the actual amount of bytes to be read is 45KB
21 Nov 08:41:10 INFO [geoserver.wcs] -
21 Nov 08:41:10 INFO [wcs2_0.util] -  Examining encoded name wcs__NO2
21 Nov 08:41:10 INFO [wcs2_0.util] -  Checking pair wcs : NO2
21 Nov 08:41:10 INFO [wcs2_0.util] -  - Namespace found wcs
21 Nov 08:41:10 INFO [wcs2_0.util] -  - Collecting layer wcs:NO2
    extension:
    service = WCS
    version = 2.0.1
    coverageId = wcs__NO2
    dimensionSubsetGroup[0] = wcs:dimensionSubset=net.opengis.wcs20.impl.DimensionSliceTypeImpl@anonymised.com (dimension: http://www.opengis.net/def/axis/OGC/0/elevation, cRS: null) (slicePoint: 450)
    dimensionSubset[0]:
        dimension = http://www.opengis.net/def/axis/OGC/0/elevation
        slicePoint = 450
21 Nov 08:41:11 INFO [geoserver.wcs] -
    extension:
    service = WCS
    version = 2.0.1
    dimensionSubset[0]:
        slicePoint = 450
21 Nov 08:41:11 INFO [wcs2_0.util] -  Examining encoded name wcs__NO2
21 Nov 08:41:11 INFO [wcs2_0.util] -  Checking pair wcs : NO2
21 Nov 08:41:11 INFO [wcs2_0.util] -  - Namespace found wcs
21 Nov 08:41:11 INFO [wcs2_0.util] -  - Collecting layer wcs:NO2
21 Nov 08:41:11 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: This request is trying to generate too much data, the limit is 40KB but the estimated amount of bytes to be written in the output is 60KB
        at org.geoserver.wcs2_0.GetCoverage.run(GetCoverage.java:272)
        at org.geoserver.wcs2_0.WCSNetCDFTest.testOutputMemoryExceeded(WCSNetCDFTest.java:94)
21 Nov 08:41:11 WARN [geoserver.ows] - OWS20SEH: handling org.vfny.geoserver.wcs.WcsException: This request is trying to generate too much data, the limit is 40KB but the estimated amount of bytes to be written in the output is 60KB
21 Nov 08:41:11 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Fri Nov 21 08:41:04 EST 2014]; root of context hierarchy
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.503 sec
Results :
Failed tests:   testRequestCoverage(org.geoserver.wcs2_0.WCSNetCDFMosaicTest): expected:<45.0> but was:<30.0>
Tests run: 7, Failures: 1, Errors: 0, Skipped: 0
[INFO] BUILD FAILURE
[INFO] Total time: 1:35.739s
[INFO] Finished at: Fri Nov 21 08:41:11 EST 2014
[INFO] Final Memory: 17M/51M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-netcdf-out: There are test failures.
[ERROR]
[ERROR] Please refer to /home/bradh/geoserver/src/community/netcdf-out/target/surefire-reports for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
