Nicola Lagomarsini created an issue |
GeoServerTileLayers are saved even if “Create cached layer” is disabled |
Issue Type: |
Bug |
Affects Versions: |
2.6.1, 2.7-beta |
Assignee: |
Components: |
GWC |
Created: |
01/Dec/14 11:35 AM |
Priority: |
Minor |
Reporter: |
Actually GeoServerTileLayers are created by default if “isCachedLayersByDefault” is set to true in the GWC default configuration. It should be better that if someone disables the “Create cached layer” checkbox for a single Layer, the related GeoServerTileLayer is not saved. |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
