Jonathan Meyer created an issue |
Issue Type: |
Improvement |
Affects Versions: |
2.6.1, 2.5.3, 2.4.8 |
Assignee: |
Components: |
Google Earth KML Output |
Created: |
12/Dec/14 12:52 PM |
Environment: |
All platforms and released GeoServer versions |
Labels: |
kml |
Priority: |
Minor |
Reporter: |
Master KML group name can be customized by the use of format_options parameter ‘kmltitle’. It would be desirable to also have layer names utilize the GeoServer layer configuration for Title and Abstract as a description, instead of the layer Name. When a layer is backed with data sources continually being fed with updated data it would also be desirable to allow specifying a format_options parameter to configure the RefreshMode and RefreshInterval on the output KML. |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
