[Geoserver-devel] [jira] (GEOS-6813) WMS GetFeatureInfo shows very poor performance in Oracle
Tom Christian created an issue
GeoServer / BugGEOS-6813
Issue Type:
BugBug
Affects Versions:
2.6.1
Assignee:
Andrea Aime
Components:
Oracle, WMS
Created:
05/Jan/15 9:54 AM
Environment:
Ubuntu Desktop 11.10 64-bit, Oracle JVM 7, Oracle Locator 11gR2
Priority:
MinorMinor
Reporter:
Tom Christian
I have a line layer in Oracle Locator 11gR2 with around 100,000 features (all 2-vertex lines, no line strings). Rendering a map showing an area within the layer, containing perhaps 500 features, is nice and fast - maybe two seconds. However, a getFeatureInfo operation with the same parameters (bbox, style, cql_filter etc.) is extremely slow - over two minutes. The issue was originally observed in a custom application but I can replicate it in the OpenLayers layer preview.
I enabled verbose logging and did some digging. The issue appears to come from the SQL query that GeoServer sends to Oracle. In GeoServer 2.2.5 getMap and getFeatureInfo, and GeoServer 2.6.1 getMap, the spatial part of the query looks like this:
SELECT … FROM … WHERE (SDO_FILTER(LINE, MDSYS.SDO_GEOMETRY(2003,4326,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(<minx>,<miny>,<maxx>,<maxy>)), ‘mask=anyinteract querytype=WINDOW’) = ‘TRUE’
However, in GeoServer 2.6.1 getFeatureInfo the spatial part looks like this:
SELECT … FROM … WHERE (SDO_FILTER(LINE, MDSYS.SDO_GEOMETRY(2003,4326,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(<minx>,<miny>,<maxx>,<maxy>)), ‘mask=anyinteract querytype=WINDOW’) = ‘TRUE’ OR (SDO_FILTER(LINE, MDSYS.SDO_GEOMETRY(2003,4326,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(<minx>,<miny>,<maxx>,<maxy>)), ‘mask=anyinteract querytype=WINDOW’) = ‘TRUE’
Presumably the severe slowdown comes from both clauses trying to do the same thing simultaneously. Perhaps if my line layer had fewer features I wouldn’t notice that this was an issue.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
