It seems like geoserver.war changes some of the default setting in Tomcat.
What I need to do:
I am using the same TOMCAT to host geoserver and other applications. One of my applications using Spring.social.twitter and twitter4j to send out tw.
Without deploying geoserver, my applications working fine without any issues. However, after I deployed geoserver, the tomcat gave me error message saying the server key is invalid: javax.net.ssl.SSLException: Server key (see log below). I tried following scenarios:
- stop geoserver service,
- undeploy geoserver app from tomcat
The error still exist
Only after I restart the tomcat service after I undeploy geoserver, the twitter function back to work.
My question:
is it possible that geoserver makes some changes on the tomcat (or JVM) that affect the twitter4j in other applications?
=======================LOG===============================
2015-01-06 11:26:11.225 INFO 17514 ? [apr-8085-exec-1] ca.polardata.controller.RootController : ==================================
2015-01-06 11:26:11.239 ERROR 17514 ? [pr-8085-exec-11] o.s.boot.context.web.ErrorPageFilter : Forwarding to error page from request [/rest/null] due to exception [Request processing failed; nested exception is org.springframework.web.client.ResourceAccessException: I/O error on GET request for “https://api.twitter.com/1.1/account/verify_credentials.json”:Server key; nested exception is javax.net.ssl.SSLException: Server key]
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.web.client.ResourceAccessException: I/O error on GET request for “https://api.twitter.com/1.1/account/verify_credentials.json”:Server key; nested exception is javax.net.ssl.SSLException: Server key
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:973)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:852)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:837)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.springframework.web.filter.HiddenHttpMethodFilter.doFilterInternal(HiddenHttpMethodFilter.java:77)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.springframework.boot.context.web.ErrorPageFilter.doFilter(ErrorPageFilter.java:109)
at org.springframework.boot.context.web.ErrorPageFilter.access$000(ErrorPageFilter.java:59)
at org.springframework.boot.context.web.ErrorPageFilter$1.doFilterInternal(ErrorPageFilter.java:88)
at org.springframework.boot.context.web.ErrorPageFilter.doFilter(ErrorPageFilter.java:101)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:931)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1004)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1822)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.springframework.web.client.ResourceAccessException: I/O error on GET request for “https://api.twitter.com/1.1/account/verify_credentials.json”:Server key; nested exception is javax.net.ssl.SSLException: Server key
at org.springframework.web.client.RestTemplate.doExecute(RestTemplate.java:567)
at org.springframework.web.client.RestTemplate.execute(RestTemplate.java:527)
at org.springframework.web.client.RestTemplate.getForObject(RestTemplate.java:259)
at org.springframework.social.twitter.api.impl.UserTemplate.getUserProfile(UserTemplate.java:55)
at ca.polardata.controller.RootController.home(RootController.java:113)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.springframework.web.method.support.InvocableHandlerMethod.invoke(InvocableHandlerMethod.java:215)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:132)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:104)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandleMethod(RequestMappingHandlerAdapter.java:749)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:689)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:83)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:938)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:870)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:961)
… 31 common frames omitted
Caused by: javax.net.ssl.SSLException: Server key
at sun.security.ssl.Handshaker.throwSSLException(Handshaker.java:1212)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:279)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:878)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:814)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1016)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1312)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1339)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1323)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:563)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:153)
at org.springframework.http.client.SimpleBufferingClientHttpRequest.executeInternal(SimpleBufferingClientHttpRequest.java:75)
at org.springframework.http.client.AbstractBufferingClientHttpRequest.executeInternal(AbstractBufferingClientHttpRequest.java:48)
at org.springframework.http.client.AbstractClientHttpRequest.execute(AbstractClientHttpRequest.java:53)
at org.springframework.http.client.InterceptingClientHttpRequest$RequestExecution.execute(InterceptingClientHttpRequest.java:94)
at org.springframework.social.oauth1.OAuth1RequestInterceptor.intercept(OAuth1RequestInterceptor.java:48)
at org.springframework.http.client.InterceptingClientHttpRequest$RequestExecution.execute(InterceptingClientHttpRequest.java:84)
at org.springframework.http.client.InterceptingClientHttpRequest.executeInternal(InterceptingClientHttpRequest.java:69)
at org.springframework.web.client.RestTemplate.doExecute(RestTemplate.java:551)
… 48 common frames omitted
Caused by: java.security.spec.InvalidKeySpecException: Unknown KeySpec type: java.security.spec.ECPublicKeySpec
at org.bouncycastle.jce.provider.asymmetric.ec.KeyFactory.engineGeneratePublic(Unknown Source)
at java.security.KeyFactory.generatePublic(KeyFactory.java:334)
at sun.security.ssl.HandshakeMessage$ECDH_ServerKeyExchange.<init>(HandshakeMessage.java:1057)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:274)
… 67 common frames omitted
