[Geoserver-devel] [jira] (GEOS-6832) WPS binding exception when producing outputs
Alessio Fabiani created an issue
GeoServer / BugGEOS-6832
Issue Type:
BugBug
Affects Versions:
2.7-beta
Assignee:
Andrea Aime
Components:
WPS
Created:
14/Jan/15 10:49 AM
Priority:
MajorMajor
Reporter:
Alessio Fabiani
Getting a Binding Exception when executing a WPS request.
Attached the ExecuteRequest along with the full log and stacktrace
2015-01-14 17:44:51,799 DEBUG [geoserver.filters] - Created BufferedRequestWrapper with String: "<?xml version=“1.0” encoding=“UTF-8”?>
<wps:Execute version=“1.0.0” service=“WPS” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns=“http://www.opengis.net/wps/1.0.0” xmlns:wfs=“http://www.opengis.net/wfs” xmlns:wps=“http://www.opengis.net/wps/1.0.0” xmlns:ows=“http://www.opengis.net/ows/1.1” xmlns:gml=“http://www.opengis.net/gml” xmlns:ogc=“http://www.opengis.net/ogc” xmlns:wcs=“http://www.opengis.net/wcs/1.1.1” xmlns:xlink=“http://www.w3.org/1999/xlink” xsi:schemaLocation=“http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd”>
<ows:Identifier>gs:Aggregate</ows:Identifier>
<wps:DataInputs>
<wps:Input>
<ows:Identifier>features</ows:Identifier>
<wps:Reference mimeType=“text/xml” xlink:href=“http://geoserver/wfs” method=“POST”>
<wps:Body>
<wfs:GetFeature service=“WFS” version=“1.0.0” outputFormat=“GML2” xmlns:it.geosolutions=“http://www.geo-solutions.it”>
<wfs:Query typeName=“it.geosolutions:comuni_01”/>
</wfs:GetFeature>
</wps:Body>
</wps:Reference>
</wps:Input>
<wps:Input>
<ows:Identifier>aggregationAttribute</ows:Identifier>
<wps:Data>
<wps:LiteralData>SHAPE_LENG</wps:LiteralData>
</wps:Data>
</wps:Input>
<wps:Input>
<ows:Identifier>function</ows:Identifier>
<wps:Data>
<wps:LiteralData>Average</wps:LiteralData>
</wps:Data>
</wps:Input>
<wps:Input>
<ows:Identifier>singlePass</ows:Identifier>
<wps:Data>
<wps:LiteralData>True</wps:LiteralData>
</wps:Data>
</wps:Input>
</wps:DataInputs>
<wps:ResponseForm>
<wps:RawDataOutput mimeType=“text/xml”>
<ows:Identifier>result</ows:Identifier>
</wps:RawDataOutput>
</wps:ResponseForm>
</wps:Execute>
" as buffer
2015-01-14 17:44:51,799 INFO [geoserver.filters] - 127.0.0.1 “POST /geoserver/ows?strict=true” “Java/1.7.0_51” “” request-size: 1839 body:
<wps:DataInputs>
<wps:Input>
<wps:Body>
</wfs:GetFeature>
</wps:Body>
</wps:Reference>
</wps:Input>
<wps:Input>
<wps:Data>
</wps:Data>
</wps:Input>
<wps:Input>
<wps:Data>
</wps:Data>
</wps:Input>
<wps:Input>
<wps:Data>
</wps:Data>
</wps:Input>
</wps:DataInputs>
<wps:ResponseForm>
</wps:ResponseForm>
</wps:Execute>
2015-01-14 17:44:51,800 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/ows]
2015-01-14 17:44:51,800 DEBUG [ows.OWSHandlerMapping] - Mapping [/ows] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2015-01-14 17:44:51,801 DEBUG [geoserver.requests] - First 4 bytes of XML doc are : 3C (‘<’) 3F (‘?’) 78 (‘x’) 6D (‘m’)
2015-01-14 17:44:51,801 DEBUG [geoserver.requests] - Charset detection phase 1. Inferred encoding: UTF-8
2015-01-14 17:44:51,802 DEBUG [geoserver.requests] - Charset detection phase 2. Charset in XML declaration is UTF-8.
2015-01-14 17:44:51,802 DEBUG [geoserver.requests] - Trying to create reader basing on existing charset information: UTF-8.
2015-01-14 17:44:51,802 DEBUG [geoserver.ows] - Raw XML request starts with: <?xml version=“1.0” encoding=“UTF-8”?>
<wps:DataInputs>
<wps:Input>
<wps:Body>
2015-01-14 17:44:51,803 WARN [geoserver.ows] - Could not get a ServiceInfo for service wps thus could not check if the service is enabled
2015-01-14 17:44:51,867 DEBUG [geotools.xml] - schemaLocation found: http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd
2015-01-14 17:44:51,871 DEBUG [geotools.xml] - Found override for http://www.opengis.net/wps/1.0.0: http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd ==> jar:file:/C:/Users/Alessio/.m2/repository/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/gt-xsd-wps-13-SNAPSHOT.jar!/org/geotools/wps/wpsAll.xsd
2015-01-14 17:44:51,877 DEBUG [geotools.xml] - No schemaLocation found, using 'http://www.opengis.net/wfs jar:file:/C:/Users/Alessio/.m2/repository/org/geotools/xsd/gt-xsd-wfs/13-SNAPSHOT/gt-xsd-wfs-13-SNAPSHOT.jar!/org/geotools/wfs/v1_1/wfs.xsd
2015-01-14 17:44:51,883 DEBUG [geotools.xml] - Found override for http://www.opengis.net/wfs: jar:file:/C:/Users/Alessio/.m2/repository/org/geotools/xsd/gt-xsd-wfs/13-SNAPSHOT/gt-xsd-wfs-13-SNAPSHOT.jar!/org/geotools/wfs/v1_1/wfs.xsd ==> jar:file:/C:/Users/Alessio/.m2/repository/org/geotools/xsd/gt-xsd-wfs/13-SNAPSHOT/gt-xsd-wfs-13-SNAPSHOT.jar!/org/geotools/wfs/v1_1/wfs.xsd
2015-01-14 17:44:51,890 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2015-01-14 17:44:51,890 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2015-01-14 17:44:51,903 DEBUG [wps.resource] - Associating process with execution id: b830866d-66f8-4531-ad80-4d7dc19438f2
2015-01-14 17:44:51,907 DEBUG [process.factory] - Failed to locate the field false in class class org.geotools.process.vector.AggregateProcess
2015-01-14 17:44:51,907 DEBUG [process.factory] - Failed to locate the field false in class class java.lang.Boolean
2015-01-14 17:44:51,908 DEBUG [geoserver.wps] - Saving status ExecutionStatus [processName=gs:Aggregate, executionId=b830866d-66f8-4531-ad80-4d7dc19438f2, asynchronous=false, phase=QUEUED, progress=0.0, userName=anonymous, creationTime=Wed Jan 14 17:44:51 CET 2015, completionTime=null, lastUpdated=Wed Jan 14 17:44:51 CET 2015, task=null, exception=null, nodeId=VEGA]
2015-01-14 17:44:51,915 DEBUG [geoserver.wps] - Saving status ExecutionStatus [processName=gs:Aggregate, executionId=b830866d-66f8-4531-ad80-4d7dc19438f2, asynchronous=false, phase=RUNNING, progress=0.0, userName=anonymous, creationTime=Wed Jan 14 17:44:51 CET 2015, completionTime=null, lastUpdated=Wed Jan 14 17:44:51 CET 2015, task=Retrieving/parsing process input: aggregationAttribute, exception=null, nodeId=VEGA]
2015-01-14 17:44:51,915 DEBUG [geoserver.wps] - Saving status ExecutionStatus [processName=gs:Aggregate, executionId=b830866d-66f8-4531-ad80-4d7dc19438f2, asynchronous=false, phase=RUNNING, progress=0.0, userName=anonymous, creationTime=Wed Jan 14 17:44:51 CET 2015, completionTime=null, lastUpdated=Wed Jan 14 17:44:51 CET 2015, task=Retrieving/parsing process input: features, exception=null, nodeId=VEGA]
2015-01-14 17:44:51,917 DEBUG [geoserver.requests] - Query is org.geoserver.wfs.request.Query$WFS11@anonymised.com
To gt2: Query:
feature type: comuni_01
filter: Filter.INCLUDE
[properties: ALL ]
2015-01-14 17:44:51,917 DEBUG [geoserver.wps] - Saving status ExecutionStatus [processName=gs:Aggregate, executionId=b830866d-66f8-4531-ad80-4d7dc19438f2, asynchronous=false, phase=RUNNING, progress=0.0, userName=anonymous, creationTime=Wed Jan 14 17:44:51 CET 2015, completionTime=null, lastUpdated=Wed Jan 14 17:44:51 CET 2015, task=Retrieving/parsing process input: singlePass, exception=null, nodeId=VEGA]
2015-01-14 17:44:51,918 DEBUG [geoserver.wps] - Saving status ExecutionStatus [processName=gs:Aggregate, executionId=b830866d-66f8-4531-ad80-4d7dc19438f2, asynchronous=false, phase=RUNNING, progress=0.0, userName=anonymous, creationTime=Wed Jan 14 17:44:51 CET 2015, completionTime=null, lastUpdated=Wed Jan 14 17:44:51 CET 2015, task=Retrieving/parsing process input: function, exception=null, nodeId=VEGA]
2015-01-14 17:44:51,919 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2015-01-14 17:44:51,919 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2015-01-14 17:44:51,919 DEBUG [process.factory] - Failed to locate the field false in class class org.geotools.process.vector.AggregateProcess
2015-01-14 17:44:51,919 DEBUG [process.factory] - Failed to locate the field false in class class java.lang.Boolean
2015-01-14 17:44:51,938 DEBUG [geotools.jdbc] - CREATE CONNECTION
2015-01-14 17:44:51,942 DEBUG [geotools.jdbc] - SELECT count AS gt_result_ FROM (SELECT * FROM “public”.“comuni_01” LIMIT 1000000) gt_limited_
2015-01-14 17:44:51,951 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2015-01-14 17:44:51,951 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2015-01-14 17:44:51,952 DEBUG [geotools.jdbc] - CLOSE CONNECTION
2015-01-14 17:44:51,953 DEBUG [geotools.jdbc] - CREATE CONNECTION
2015-01-14 17:44:51,954 DEBUG [geotools.jdbc] - SELECT “gid”,“COD_REG”,“COD_PRO”,“COD_ISTAT”,“PRO_COM”,“NOME”,“SHAPE_LENG”,“SHAPE_AREA”,“A_2002",“A2003","A2004”,“A2005","A2006”,“A2007","A2008”,“A**2009”,"A_2010”,encode(ST_AsEWKB(“geom”),‘base64’) as “geom” FROM “public”.“comuni_01” LIMIT 1000000
2015-01-14 17:44:54,199 DEBUG [geotools.jdbc] - CLOSE CONNECTION
2015-01-14 17:44:54,230 DEBUG [geoserver.wps] - Saving status ExecutionStatus [processName=gs:Aggregate, executionId=b830866d-66f8-4531-ad80-4d7dc19438f2, asynchronous=false, phase=RUNNING, progress=50.0, userName=anonymous, creationTime=Wed Jan 14 17:44:51 CET 2015, completionTime=null, lastUpdated=Wed Jan 14 17:44:54 CET 2015, task=Execution completed, preparing to write response, exception=null, nodeId=VEGA]
2015-01-14 17:44:54,231 DEBUG [geoserver.wps] - Saving status ExecutionStatus [processName=gs:Aggregate, executionId=b830866d-66f8-4531-ad80-4d7dc19438f2, asynchronous=false, phase=RUNNING, progress=50.0, userName=anonymous, creationTime=Wed Jan 14 17:44:51 CET 2015, completionTime=null, lastUpdated=Wed Jan 14 17:44:54 CET 2015, task=Writing outputs, exception=null, nodeId=VEGA]
2015-01-14 17:44:54,233 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2015-01-14 17:44:54,233 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2015-01-14 17:44:54,239 DEBUG [geoserver.wps] - Saving status ExecutionStatus [processName=gs:Aggregate, executionId=b830866d-66f8-4531-ad80-4d7dc19438f2, asynchronous=false, phase=SUCCEEDED, progress=100.0, userName=anonymous, creationTime=Wed Jan 14 17:44:51 CET 2015, completionTime=Wed Jan 14 17:44:54 CET 2015, lastUpdated=Wed Jan 14 17:44:54 CET 2015, task=null, exception=null, nodeId=VEGA]
2015-01-14 17:44:54,239 INFO [geoserver.wps] -
Request: execute
service = WPS
version = 1.0.0
baseUrl = http://localhost:8080/geoserver/
identifier:
value = gs:Aggregate
dataInputs:
input[0]:
identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com (value: features, codeSpace: null)
reference = net.opengis.wps10.impl.InputReferenceTypeImpl@anonymised.com (body: net.opengis.wfs.impl.GetFeatureTypeImpl@anonymised.com (handle: null, service: WFS, version: 1.0.0, baseUrl: null, providedVersion: null, extendedProperties: {}) (maxFeatures: null, outputFormat: GML2, resultType: <unset>, traverseXlinkDepth: null, traverseXlinkExpiry: null, formatOptions: null, metadata: null, startIndex: null, viewParams: null), encoding: null, href: http://geoserver/wfs, method: POST, mimeType: text/xml, schema: null)input[0]:
identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com (value: aggregationAttribute, codeSpace: null)
data = net.opengis.wps10.impl.DataTypeImpl@anonymised.com[0]:
identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com (value: function, codeSpace: null)
data = net.opengis.wps10.impl.DataTypeImpl@anonymised.com.[0]:
identifier = net.opengis.ows11.impl.CodeTypeImpl@anonymised.com (value: singlePass, codeSpace: null)
responseForm:
rawDataOutput:
identifier = net.opengis.ows11.impl.CodeTypeImpl@…4184… (value: result, codeSpace: null)
mimeType = text/xml
2015-01-14 17:44:54,241 ERROR [geoserver.ows] -
org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException: index=0, size=0
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:352)
at org.geoserver.wps.response.ExecuteProcessResponse.getMimeType(ExecuteProcessResponse.java:64)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:959)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:284)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:72)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
2015-01-14 17:44:54,269 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2015-01-14 17:44:54,269 DEBUG [geoserver.filters] - Compressing output for mimetype: application/xml
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
