Landry Breuil created an issue |
REST call on /rest/layers.xml broken when geosearch extension is enabled |
Issue Type: |
Bug |
Affects Versions: |
2.5.4 |
Assignee: |
Components: |
REST |
Created: |
15/Jan/15 2:33 AM |
Priority: |
Major |
Reporter: |
See also https://github.com/georchestra/georchestra/issues/616 When building geoserver 2.5.4 with geosearch extension enabled, there’s a conflict with REST calls. I get a 404 return code on /rest/layers.xml or /rest/workspaces.xml while /rest/layers & /rest/workspaces works fine. The error log seems to point to a geosearch codepath: > 2015-01-14 16:14:09,874 ERROR [geoserver.rest] - Layer layers not found Other calls returning xml like /rest/settings/contact.xml work fine. |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
