[Geoserver-devel] [jira] (GEOS-6851) Geoserver building broke at Gs-wps-core:WPSXStreamLoaderTest.java line :81
Lingbo Jiang created an issue
GeoServer / BugGEOS-6851
Issue Type:
BugBug
Affects Versions:
2.7-beta
Assignee:
Andrea Aime
Components:
WPS
Created:
22/Jan/15 10:04 PM
Environment:
Ubuntu14 maven 3.05 jdk_1.7
Priority:
MajorMajor
Reporter:
Lingbo Jiang
Original Estimate:
4 hours
Remaining Estimate:
4 hours
HI geoserver-devel,
While we are trying to fix the build error of Geoserver, we found it broke at the Gs-wps-core:WPSXStreamLoaderTest.java line :81(please refer the attached building output) . We tried to debug and found the reason is because file url path for a resources has space character which was encoded with “%20” . then it caused that the resources was not loaded properly and it breaks the test.
So I thought that I might report it to community. Also I added a few line code to fix the problem, please have it for reference.
Lingbo
/////////////////the building output/////////////////////////
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec <<< FAILURE!
testBackFormatXmlComatibility(org.geoserver.wps.WPSXStreamLoaderTest) Time elapsed: 4 sec <<< FAILURE!
java.lang.AssertionError
at org.junit.Assert.fail(Assert.java:86)
at org.junit.Assert.assertTrue(Assert.java:41)
at org.junit.Assert.assertTrue(Assert.java:52)
at org.geoserver.wps.WPSXStreamLoaderTest.testBackFormatXmlComatibility(WPSXStreamLoaderTest.java:81)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
/////////////////////////////// please refer the green line code change///////////////////////////
@Test
public void testBackFormatXmlComatibility() throws Exception {
GeoServer gs = createMock(GeoServer.class);
URL url = Thread.currentThread().getContextClassLoader().getResource(“org/geoserver/wps/”);
//Lingbo the url was encoded with “%20” for space.
+File file;
+try
{ + file = new File(url.toURI()); + }
catch(URISyntaxException e)
{ + file = new File(url.getPath()); + }
-File file = new File(url.getPath());
WPSXStreamLoader loader = new WPSXStreamLoader(new GeoServerResourceLoader(file));
WPSInfo wps = loader.load(gs);
boolean found1 = false;
boolean found2 = false;
for (ProcessGroupInfo pg : wps.getProcessGroups()) {
if (pg.getFactoryClass().getName().equals(“org.geoserver.wps.DeprecatedProcessFactory”))
{ assertFalse(pg.isEnabled()); found1 = true; }
if (pg.getFilteredProcesses() != null) {
for (Object opi : pg.getFilteredProcesses())
{ assertTrue(opi instanceof ProcessInfo); }
.equals(“org.geoserver.wps.jts.SpringBeanProcessFactory”))
{ assertTrue(pg.isEnabled()); assertEquals(pg.getFilteredProcesses().get(0).getName().toString(), “gs:GeorectifyCoverage”); assertEquals(pg.getFilteredProcesses().get(1).getName().toString(), “gs:GetFullCoverage”); assertEquals(pg.getFilteredProcesses().get(2).getName().toString(), “gs:Import”); found2 = true; }
assertTrue(found1);
assertTrue(found2);
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
