[Geoserver-devel] [jira] (GEOS-6879) Rendering issue with PDF output format
Mauro Bartolomeoli created an issue
GeoServer / BugGEOS-6879
Issue Type:
BugBug
Affects Versions:
2.6.2
Assignee:
Andrea Aime
Components:
WMS
Created:
12/Feb/15 4:15 AM
Priority:
MinorMinor
Reporter:
Mauro Bartolomeoli
PDF output format can draw lines that “overflow” the expected bbox. This can be clearly seen when you have two adiacent polygons sharing edges: it can happen that the edge of one polygon is longer than the one of the other. This happens when stroke-linejoin has the default value, but does not happen using “round”.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
