[Geoserver-devel] [jira] (GEOS-6880) REST API reload not taking into account gwc-gs.xml
Matthias Uden created an issue
GeoServer / BugGEOS-6880
Issue Type:
BugBug
Affects Versions:
2.3.0
Assignee:
Andrea Aime
Created:
12/Feb/15 7:48 AM
Priority:
MajorMajor
Reporter:
Matthias Uden
I’m using GeoServer 2.3.0 with GeoWebCache 1.4. I have not tested it yet, but I assume this bug also affects newer versions.
I realised that reloading the configuration via the REST API does not reload the settings configured in gwc-gs.xml
This seems to be done only on GeoServer startup, cf. the log line:
INFO [gwc.config] - Initializing GeoServer specific GWC configuration from
gwc-gs.xml
I’d like to be able to change settings in gwc-gs.xml and reload them without the need to restart the entire GeoServer.
Thanks for your help and best regards,
Matthias
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
