[Geoserver-devel] [jira] (GEOS-6894) LDAP authentication fails with "invalid DN"
Pavel Golodoniuc created an issue
GeoServer / BugGEOS-6894
LDAP authentication fails with “invalid DN”
Issue Type:
BugBug
Assignee:
Andrea Aime
stacktrace1.txt, stacktrace2.txt
Created:
19/Feb/15 10:09 PM
Environment:
GeoServer 2.6.2
Oracle Corporation: 1.7.0_71 (Java HotSpot™ 64-Bit Server VM)
Windows 8.1 64-bit
Tomcat 7
Priority:
BlockerBlocker
Reporter:
Pavel Golodoniuc
I’ve read http://docs.geoserver.org/latest/en/user/security/tutorials/ldap/index.html and tried many configuration options but still couldn’t get it to work. Numerous posts in blogs and forums reporting similar issues with LDAP authentication didn’t help much. I have seen a similar issue reported earlier GEOS-5999 and one more that I can’t find anymore…
Here’s as far as I could get:
(see stacktrace1.txt attached)
and the following gets logged in slapd syslog:
Jan 29 10:52:05 cgsrv4 slapd[3326]: conn=8628 op=0 do_bind: invalid dn ((uid=Username))
If I try to fully qualify the user lookup pattern (uid=
{0}
,ou=Users,dc=arrc,dc=csiro,dc=au) as some forum posts suggest I get the following with nothing logged in slapd logs (it looks like it doesn’t even get there):
(see stacktrace2.txt attached)
Any help of suggestions where do I need to look at will be highly appreciated.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c)
Atlassian logo
