Lorenzo Pini created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.6.2 |
Assignee: |
Components: |
Security |
Created: |
20/Feb/15 8:53 AM |
Labels: |
security authentication authorization |
Priority: |
Major |
Reporter: |
In the “Filter Chain” page ( geoserver/web/?wicket:interface=:87:::: ) I’m trying to set up a new Chain filter by moving it from the “Available” box to the “Selected” box. In the interface it works and a POST is sent with the correct values and ordering: After the change GeoServer does not react as expected and inspecting the security/config.xml file I see that the “geostore” filter is missing. … I got it working by manually changing the file, adding the <filter>geostore</filter>, and restarting GeoServer (a configuration reload does not work). |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
