Alvaro Huarte created an issue |
WPS process read incorrect result item in a concatenated wps multi-process |
Issue Type: |
Bug |
Affects Versions: |
2.7-RC1, 2.7-beta |
Assignee: |
Attachments: |
Innpacto-shapefile.zip, SxtKrigingReclassify.xml |
Components: |
WPS |
Created: |
24/Feb/15 7:58 AM |
Priority: |
Minor |
Reporter: |
When I build a wps task with two concatenated wps processes, if first of them returns by default more of one of output result items (i.e. sextante:kriging), the next wps always only gets the first item, it does not filter by name or data type to extract the correct item. I attach the WPS xml sample and the source shapefile. The task concatenates the sxt:kriging and sxt:reclassifyequalamplitude modules. |
This message was sent by Atlassian JIRA (v6.1.6#6162-sha1:7af547c) |
